Oil smell after short high speed bursts...
Old Sep 16, 2013 | 03:54 PM
photopro's Avatar
photopro
Noticed when push it a little bit for a mile or so, up to 85 or 90, and then back down to 65, and then to 30 before getting to work there is an oil smell. Its slight but in the cabin. Checked the level and its fine, just changed a few weeks ago with full synthetic. I am thinking it’s the push of the engine to higher RPM and then pressure is let off when I decelerate. I didn’t notice anything on trips earlier when the 80-90 mph jaunts are in the midst of 70 MPH crusing, e.g. interstate 77. anyone else notice this?
Old Sep 16, 2013 | 04:12 PM
Maybe you had some oil spill on a crossmember or something during the oil change and it's just that burning on the exhaust, maybe??
Old Sep 16, 2013 | 05:38 PM
rlo's Avatar
rlo
^^ What blnewt said.
I had a burning plastic smell after coming off a highway for weeks only to find out some melted plastic, probably from a grocery bag or something, was melted onto one of my exhaust pipes.
Old Sep 17, 2013 | 09:39 PM
photopro's Avatar
photopro
i thought it was that when it happened a few weeks ago and i did indeed spill some while filling but its been weeks. Maybe the increased heat from pushing it brought it back but i havent smelled it before or since. gonna try one more time at 90 and then back down and see what happens..
Old Sep 17, 2013 | 09:52 PM
keraxis's Avatar
keraxis
Check your oil filter
See if you have oil on your filter... if so your PCV valve is failing. Its job is to relieve pressure from the crank and put vapor back into the engine through the intake for recombustion. If it fails oil is able to push up from the crank and coat your filter.
Old Sep 18, 2013 | 09:55 PM
photopro's Avatar
photopro
OK! I will definitely check and see if there is oil on the outside of the filter. Is a bad/worn PCV valve synonymous with poor gas mileage also? Thanks again!
Old Sep 19, 2013 | 12:38 AM
ilovemyg37's Avatar
ilovemyg37
i have the same thing happen too. i notice it when the A/C is on and windows are always closed. if i go past 5 RPMs for a few seconds, i smell a oily smell. it doesnt smell sweet so i dont think its coolant, but possibly oily or exhausty...
been to the dealer 3 times while i was under warrenty, they said of course these cars that is normal and the a/c can suck in external exhaust fumes. funny it never happens on the rental cars...
there are a bunch of other threads on "odors under heavy acceleration" i found here and on the 370z forums, i don't think anyone has successfully diagnosed/repaired the issue (unless its a plastic bag on the undercarriage which not in my case sadly). maybe it is normal for some cars?
Old Sep 21, 2013 | 03:37 AM
photopro's Avatar
photopro
OK. it doesnt happen consistently and it was faint. I will watch for it again under similar circumstances. the infiniti dealers are the worst... thats not normal and i been driving for over 45 years! normal my a--!!
claudiohv
Sep 17, 2015 01:43 AM
sharmelan
17
Sep 14, 2015 03:18 PM
