Clock Blinking
Old Sep 12, 2013 | 07:09 PM
Paceship's Avatar
Paceship
Clock Blinking
Has anyone seen their clock have intermittent blinking? No apparent pattern to its going out for a second, then back on. Not all the time, just, as said...its now and then. Any ideas of what it may be? Thanks!!!
Old Sep 13, 2013 | 01:02 AM
esesnipey94's Avatar
esesnipey94
Pretty common issue with our cars. Had same exact issue & it gets worse. Over time it would stay off longer & become more frequent. However I'm under warranty so I just took it in & they replaced the whole clock assembly. Not exactly sure what the cause is but I'm sure if it was just the bulb behind the clock they would have just replaced that. GL
Old Sep 13, 2013 | 09:22 AM
blazeplacid's Avatar
blazeplacid
I had the same problem.
If you are under warranty take it in.
Old Sep 13, 2013 | 12:54 PM
Paceship's Avatar
Paceship
Thanks. My vehicle is a "09" and only still under powertrain warranty. Would dealer fix this issue under that portion of warranty?
Old Sep 13, 2013 | 06:31 PM
esesnipey94
I'm not sure, I would say no since it's an electrical problem, however it doesn't hurt to try. If anything you can get a quote on fixing the clock out of warranty
I hav a 2010 & they didn't even ask about warranty so you may get lucky. Doesn't hurt to try though. Let us know what they quote you if you decide I take it in.
37
Oct 17, 2020 11:12 AM
vamarris
Dec 9, 2018 11:10 AM
mikysee
Sep 28, 2015 11:18 AM
cshawsg37
Sep 25, 2015 05:33 PM
Morgan Thompson
Aug 19, 2015 04:44 PM
