Exhaust question
#61
EatShtRochester (08-22-2013)
#63
Ordered a Top Speed exhaust, at $420 shipped this is a killer deal for a catback and even with some of the variables, saving $500-1000$ vs other options its worth the risk of having to make slight modifications.
I will be painting my canisters, not sure if I will go gloss black, or flat black, input?
Thanks for those that have helped
#64
I think I'd go flat black mainly because flat paint tends to bond better than gloss on shinier surfaces. And I'd paint all the way up the back end of the tip leaving just the large cylinder unpainted. I just painted the cans and left the whole tip all the way to the can weld unpainted and it would look best if I went w/ what I just described. Look forward to seeing pics when you get it done (and also your review). At $420 that's a real nice price
#65
From this pic you'll see what I mean, instead of leaving the whole tip from where it's welded to the can all the way to the end unpainted I'd paint from the weld up to where the tip makes it's final angle and flattens (leaving the large diameter unpainted (about the last 5" of the tip). Hope that makes sense.
#66
No wonder Stillen dnyo'd their 2.5 inch Cat-back at 18hp on the G Coupe/Sedan and 370Z. I'm guessing Infiniti went with the really small diameter stock setup to keep NVH low.
