Poor man's G37 sedan mod page!
Old Sep 15, 2016 | 03:40 PM
  #241
luiz132's Avatar
luiz132
bump
Old Sep 15, 2016 | 06:24 PM
  #242
nipplygoodness's Avatar
nipplygoodness
$10 in primer and paint, and you can customize your engine cover. Here's mine:
There goes my last $10 aha
Old Sep 25, 2016 | 02:53 AM
  #243
OMYG37S's Avatar
OMYG37S
have you guys talked about a driver's side keyhole delete mod on here yet?
i just did it and it looks great, cost 35-40 bux and takes 5 minutes.
Old Sep 26, 2016 | 12:28 PM
  #244
gman69's Avatar
gman69
Does it just pop back off?? If not how are you gonna get into your car if the fob battery dies?
Old Sep 26, 2016 | 12:34 PM
  #245
gman69's Avatar
gman69
Originally Posted by avidas2000
Where can I find this? Can't seem to find it in diode dynamics website.
Me toooooo.... Guess they stopped making them..
Old Sep 26, 2016 | 12:39 PM
  #246
You pull on the handle so that you can get a little flat-edge in there and pop off the cover. However, if you keep said screwdriver in the car...
Old Sep 26, 2016 | 01:03 PM
  #247
Dembflyr's Avatar
Dembflyr
Not sure if this has been mentioned in this thread. Poor mans engine dress up bolt. Cost $0. I used some left over paint.
Used this card board as a template so I know where they go back.
Then I split them up into the two colors I wanted to use.
All done
Now, I know there's the "but they will just chip when you tighten them down" comments coming.
Most of these do not need to be super tight. The ones that do wind up chipping you can easily touch up with a small brush.
Now time to save my pennies for a proper dress up bolt kit.
Old Sep 26, 2016 | 01:12 PM
  #248
OMYG37S's Avatar
OMYG37S
if its IN the locked car... you wont be able to unlock the car to get to it... but the key itself should be enough to force it off in an emergency. worst case scenario, you break a tab and your out 35 bux
the fob batteries last a while, and the car will warn you for weeks/months before it completely dies.
it pops off pretty easily. the latch could be modified a bit to make access more reliable.
Old Sep 26, 2016 | 02:42 PM
  #249
Daddy Fat Sacs's Avatar
Daddy Fat Sacs
Not bad looking as a hold me over...but if you want quality and at a great price...
ZSPEC Nissan 370z Z34 & Infiniti G37/Q50 Platforms ('09-17) - "Ultimate" Dress-Up Engine Bay Fastener Kit - ZSPEC Design - "Enhance Your Ride"
Old Dec 24, 2016 | 01:06 PM
  #250
Project-vipg's Avatar
Project-vipg
Originally Posted by buckets
a really inexpensive mod that makes a genuine difference: reverse the shift direction of your automatic in manual mode. if you can just swap the pin spots its free other you need some heatshrink and splice barrels or you could solder the wires back together.
That's a great idea that's one of those things I always wish was different, may have to look into this now.
Old Feb 12, 2017 | 12:45 AM
  #251
OMYG37S's Avatar
OMYG37S
ive done many of the better suggestion in this thread, but i dont think this ones been mentioned yet, i installed a 3rd brake light flasher the other night. it was 30 bux.
Vehicle Brake Light Flasher Module with brake force monitor Vehicle Brake Light Flasher Module with Brake Force Trigger. [FLSHR_G1] - $29.95 : 3rd Brake Flasher Web Site
its got accelerometers and you can program different patterns for medium/heavy braking.
video:
https://goo.gl/photos/D2p2b2UP7PKVGUdQ7
Old Feb 13, 2017 | 10:02 PM
  #252
STownSaint's Avatar
STownSaint
^looks kinda odd...and likely illegal? As in, attention grabbing for the law-enforcing contingent
Old Feb 13, 2017 | 10:33 PM
  #253
OMYG37S's Avatar
OMYG37S
looking odd is the goal, hopefully its odd enough to alert any distracted or weary drivers that im braking.
its perfectly legal as per California vehicle Code 25251.5. (c) as long as you program it to be so. Your state may vary.
(a) Any motor vehicle may also be equipped with a system in which an amber light is center mounted on the rear of a vehicle to communicate a component of deceleration of the vehicle, and which light pulses in a controlled fashion at a rate which varies exponentially with a component of deceleration.
(b) Any motor vehicle may be equipped with two amber lamps on the rear of the vehicle which operate simultaneously with not more than four flashes within four seconds after the accelerator pedal is in the deceleration position and which are not lighted at any other time.  The lamps shall be mounted at the same height, with one lamp located on each side of the vertical centerline of the vehicle, not higher than the bottom of the rear window, or if the vehicle has no rear window, not higher than 60 inches.  The light output from each of the lamps shall not exceed 200 candlepower at any angle horizontal or above.  The amber lamps may be used either separately or in combination with another lamp.
(c) Any stoplamp or supplemental stoplamp required or permitted by Section 24603 may be equipped so as to flash not more than four times within the first four seconds after actuation by application of the brakes.
also, you can set it to function normally except for when it senses an increase rate of braking force, for example, you start braking slowly and then realize you need to stop sooner and apply more brakes, normal lights couldnt convey this change (it would be up to the driver to interpret the new deceleration rate), but this module can.
ive actually reprogrammed it since the video to be more conservative in its flashing. this includes a short lock out period where it wont flash after brakes have already been applied once
Old Feb 14, 2017 | 08:27 AM
  #254
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
I forgot this thread existed, this is like home base for me, EVRYTHING IS ON A BUDGET!!!
Old Feb 14, 2017 | 08:33 AM
  #255
Here's a recent budget mod... $15 for a 12"x24" sheet of 3M vinyl in textured CF, and $7 for a spray can of adhesion promoter.
