Noise from headliner
Old Jan 29, 2013 | 09:47 AM
MalbecG37S's Avatar
MalbecG37S
I've been on a hunt-and-fix mission lately regarding interior noises. Found one in the rear deck that was actually associated with the car seat clips..whatever they are called. Small pieces of electrical tape - invisible to the eyes - fixed that one.
But there is one that is hard to describe coming from the headliner. I wouldn't call it a creak - but that is a close description. The sound is more like...imagine a walmart plastic bag is under the headliner ....or...it is almost as if it is something sticky that is becoming 'unstuck' and 'restuck'. Very hard to describe.
Anyone else have this? And - any known fix?
FYI - my car did have hail damage fixed last spring - so yes, the headliner was removed and reinstalled.
Old Jan 29, 2013 | 10:10 AM
BLamb's Avatar
BLamb
I had one in the headliner when I first got the car. I just started pressing on different areas until I could recreate the squeak, turned out to be just behind the sunroof toward the drivers side. I pressed it up and down at that spot a bunch of times and eventually it stopped making noise, I think you're right about it being something sticky that comes un stuck.
Old Jan 29, 2013 | 12:19 PM
MalbecG37S's Avatar
MalbecG37S
I've tried that....looks like I will be trying again!
Thanks for the reply!
Old Jan 29, 2013 | 12:42 PM
Chi-City-G's Avatar
Chi-City-G
If it is in some way a creak... lubricating the rubber round the outside lining of the moonroof is something I have had to do almost once a season. it is worth a try...
Old Jan 29, 2013 | 03:27 PM
MalbecG37S's Avatar
MalbecG37S
Thanks - will definitely give that a try as well...as you said - it's worth a try...
Old Apr 23, 2015 | 01:48 PM
white3696's Avatar
white3696
i just joined and was looking for almost exactly as you put it on the headliner mysterious noise(s),,,that is what is happening in my '13 G37,,,thanks for the analogy. any luck/update on that 'plastic bag under the headliner' sound?
Old Apr 23, 2015 | 03:58 PM
HoldmyMouse's Avatar
HoldmyMouse
It's very likely the Velcro tape came loose or no longer stick. Permanent fix is to replace the tape or put insulation in between.
Old Apr 24, 2015 | 01:41 PM
Red00lght's Avatar
Red00lght
Mine was making the same noise in the same spot. It was driving me nuts and was worse with the sunroof shade open. I opened the sunroof and closed it again and noise disappeared. Keeping my fingers crossed!! Haha
Old Apr 27, 2015 | 06:09 PM
socketz67's Avatar
socketz67
Community Builder
I have always had this one as well.
Almost as annoying as the rattle from the bottom of the passenger seat which is tied to the plastic finish trim piece along the sliding rail coming loose.
Or, the one in the console that squeaks until you lodge your hand between the console and passenger seat.
Old Apr 27, 2015 | 06:56 PM
Red00lght's Avatar
Red00lght
I find it amazing my 2013 g37 has multiple rattles coming from dash, door, and headliner yet my 2003 f150 lightning with 200,000 miles is solid as a rock and rattle free?!
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
MrRiv
Sep 29, 2015 04:59 PM
Slapshot1
Sep 27, 2015 08:40 AM
