Clutch Pedal Noise
Old Jan 28, 2013 | 08:16 PM
JWise1203's Avatar
JWise1203
Clutch Pedal Noise
Hey guys,
My 2012 G37S has started making noise within the past two weeks. Anyone else had issues similar to my video below?
Old Jan 28, 2013 | 09:12 PM
therustytrombon's Avatar
therustytrombon
Yup, took it to the dealer, they said some part of the clutch pedal assembly was worn and installed a new one under warranty.
Old Jan 28, 2013 | 09:51 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Mine will make a noise like that if I keep depressing/releasing the pedal many times after turning off the car. Noise goes away after car is started. Doesn't make a whole lot of sense why.
Is the pedal action smooth, non binding on both the down/up strokes?
@therusty, what part did they replace? A bushing(s) of some sort I bet..
Old Jan 28, 2013 | 09:54 PM
JWise1203's Avatar
JWise1203
Pedal action is fairly smooth. It is not binding. I can feel vibration in the pedal when it creaks like in the video.
Old Jan 28, 2013 | 10:04 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Sounds like a bushing or spring then.
If you've never changed the assist spring, the bushings are relatively easy to get to, and may just require a bit of lubrication (white lithium grease).
The bushing is actually part of the clevis, so you can really only lubricate the pins.
To get at the bottom pin, remove the C clip, then depress the pedal to unload it and slide the pin to your left.
The top is done the say way, but getting the pin out and back in is a real pain, so be careful you don't drop it behind the fuse box (don't ask).
Also, it could be your spring that's making the noise too. In fact, before doing anything, I'd remove the spring (visible in the pic above) and see if it still does the noise.
Btw, assuming yours is stock, it'll be alot thicker and probably yellow.
Old Jan 28, 2013 | 10:05 PM
Dude you have huge feet.
Old Jan 28, 2013 | 10:14 PM
JWise1203's Avatar
JWise1203
Hahaha! Not really, it's just the angle of the video.
Old Jan 28, 2013 | 10:36 PM
It's ok man. I wear a 15. I know big feets when I see them.
I agree with what's been stated. Lubricating the upper and lower pin might help. You can do it without removing them. Use PB Blaster lithium grease in the spray can. Shield the carpet behind it so you don't make a mess when you spray.
White Lithium Grease
Old Jan 28, 2013 | 11:30 PM
therustytrombon
On the work order it says "C/S when pressing the clutch it makes a clicking noise when engaged - replaced clutch pedal assembly - pedal binding"
Part 46503-JJ80C
Old Jan 28, 2013 | 11:43 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Sure... Why bother spending 15 min to lube a bushing when you can replace the whole thing for a half hour, while billing out an hour. Brilliant.
Old Jan 30, 2013 | 08:18 AM
Beama00's Avatar
Beama00
I have the same issue! Dealer has lubed it a few times, that's only a temporary fix. Never had this problem on my 08 coupe - different clutch I was told.
Old May 26, 2015 | 11:26 PM
SON415's Avatar
SON415
Old thread but was this ever fixed? same problem wiht my coupe
linvbro
Aug 22, 2016 01:25 PM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
