strange noise
Old Sep 21, 2012 | 12:25 PM
ged1067's Avatar
ged1067
strange noise
on my G37s. Sounds like there's a window open somewhere. It's that same kind of pulsating noise, but I don't see anything open.
Any ideas out there?
GED
Old Sep 21, 2012 | 12:27 PM
G37Sam's Avatar
G37Sam
What speeds are we talking about here?
Old Sep 21, 2012 | 12:33 PM
ged1067's Avatar
ged1067
seem like pretty much all speeds. no noise when stopped, just when moving. Don't think it's tires. Just have no clue.
GED
Old Sep 21, 2012 | 12:52 PM
godzilla619's Avatar
godzilla619
sunroof? maybe if you uploaded a video of the sound we could help, this is pretty vague description.
Old Sep 21, 2012 | 01:16 PM
SlimTV's Avatar
SlimTV
Have someone else drive the car while you sit in the back seat and listen for the sound as you know exactly what you're listening for. The noise will be amplified much more if the ground is wet while driving. Usually a door seal or window seal is the culprit. You didnt say if it was coming from the front or rear. I've noticed in older cars ive owned that sometimes the door glass pinches the seal upon rolling up the window like when parking the car for the night. The glass creates a permanent groove in the rubber, and it can sit like that for long periods of time undetected. I've also had situations where the glue at the corners of the windshield either rotted or dried out causing a light whooshing/whistling sound at highway speeds. Another area to inspect is the sunroof. I've seen a drop or two of water drip down from my roof in the carwash when its being blasted by high water pressure. If your G is under warranty, I'd just have the dealer check it out and let them go crazy replacing stuff for free.
Old Sep 22, 2012 | 05:57 AM
INFINITI G37's Avatar
INFINITI G37
Do u tilt up ur sunroof ??
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
MrRiv
Sep 29, 2015 04:59 PM
Slapshot1
Sep 27, 2015 08:40 AM
