AC/ Fan smells
Old Dec 18, 2011 | 01:29 AM
jhenka's Avatar
jhenka
AC/ Fan smells
Hey guys I got a newb question. Since i usually drive with my windows down and don't turn on my ac/ fans i never noticed this issue... Yesterday i turned my ac/fan on and this putrid moldy/ wet smell filled the car. Any ideas what it may be?
Old Dec 18, 2011 | 02:17 AM
Ibanez540r's Avatar
Ibanez540r
It's usually caused by moisture being left in the A/C system after shutting down and getting nasty. You should run the fan for a few minutes after shutting off A/C prior to turning the car off so the moisture can evaporate, etc.
Don't forget defrost also runs A/C so applies as well.
Old Dec 18, 2011 | 02:24 AM
jhenka's Avatar
jhenka
Thanks bro thats probably it.. I'll try it out tomorrow we'll see how it goes!
Old Dec 18, 2011 | 09:32 PM
TinsleyC's Avatar
TinsleyC
You likely need to replace your cabin air filter.
Old Dec 19, 2011 | 08:15 AM
This^ I get mine at Amazon, get my cabin, and air filters all at once for free shipping
http://www.amazon.com/s/ref=nb_sb_no...ilters&x=0&y=0
Simple 10 minute DIY too, if you haven't done it here's one of several threads on it
https://www.myg37.com/forums/d-i-y-i...-box-bulb.html
Old Dec 19, 2011 | 01:08 PM
ReddieG37's Avatar
ReddieG37
As mentioned earlier, you probably need to replace your cabin filter. Have you replaced the cabin filter yet?
Old Dec 19, 2011 | 01:33 PM
Racer_X's Avatar
Racer_X
My '08 only has 21k on it, but I'm going to change the filter to the carbon one, thanks the links!
Old Dec 20, 2011 | 02:21 AM
bleu ardoise's Avatar
bleu ardoise
Cause:
This is caused by mildew in your evaporator, changing out your cabin filter won't remove the odor causing mildew. This is very common across many auto manufacturers, it's caused when you turn off the car a/c system and water is left sitting in the evaporator unit. It sits and starts to grow mold over time, you can avoid this by running the a/c in non re-circulation mode more often and making sure the drain holes aren't plugged up.
Solution:
Many people myself included have used Lysol to kill the mold, be very careful but this is what I've done, keep in mind this was done on another car I owned I haven't tried this on my G but should work just fine. Turn on the car, turn on the defroster to high and turn the heat on full blast. Pour diluted Lysol 1:1 with water down the intake vents at the top of the hood. GET out of the car and let it run for 15-20 min, you can be very liberal with the Lysol just don't inhale it in the car!!
Maintenance:
I usually turn off my A/C about 3 miles before I get home, keep running the blower motor and tun off the re-circulation mode, this should dry out the evaporator and keep the system open so hopefully it will remain dry overnight. Keep in mind this happens more so in high humidity regions, thank god I moved to Arizona!
You can also use this product: DWD2 - Home and have a dealer clean it up.
Good luck!
Old Dec 20, 2011 | 02:30 AM
jhenka's Avatar
jhenka
Nope i have 25k and still running all the same air filters.
Thanks for the links i'll replace them soon.
I haven't replaced it yet but I'm petty sure the evaporation idea was the culprit. It stopped for now but we'll see in the future.
Victory
17
Oct 27, 2022 03:45 PM
Amaadkhan2k
Oct 11, 2015 11:52 AM
G37sPhoton
Oct 4, 2015 11:08 PM
claudiohv
Sep 17, 2015 01:43 AM
