expensive mistake -- looking for the electricians (basic)
Old Sep 21, 2011 | 01:09 PM
eksigned's Avatar
eksigned
As far as I remember between the coupe and sedan there are some differences in the wiring harness.
What did you used to protect the housing while it's being baked? That looks pretty darn bad! Was the electronic ballast baked also?
nothing actually (even the time i correctly baked them shortly afterwards). the ballast is in tact. that line just fell off the pan i had placed under the unit. it caught fire and caused some disfiguration in the plastic...everything else seems to be in tact
Old Sep 21, 2011 | 01:11 PM
ucla bruin's Avatar
ucla bruin
You'll have to cut the original connector off and use the Radio Shack ones. Or you can get it from riskyguy or someone else, which is probably better.
__________________
Old Sep 21, 2011 | 01:14 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
I may have an extra one. I'll check and get back to you!
Old Sep 21, 2011 | 01:55 PM
Weiboy718's Avatar
Weiboy718
dam, if you're going to do this again. Use cardboard. The heat from the metal pan will melt any kind of plastic. I'm very sorry to say this, but I hope your ballast will still work. I have no proof that the oven will or destroy a electronics ballast, I can only tell you this: when I started baking lights years ago, I left all the bulbs intact when baking it and those bulbs ends up shorting a fuse. Idk why, but that's what I learned over the years. Hopefully your ballast will still work.
Old Sep 21, 2011 | 02:11 PM
Blackjack's Avatar
Blackjack
Why were the wires in the oven?
Old Sep 21, 2011 | 02:49 PM
eksigned's Avatar
eksigned
stupidity? it was a single one that i assumed couldnt be unhooked...
Old Sep 21, 2011 | 03:15 PM
jhenka's Avatar
jhenka
I should have it, I'll let you know when i get home...
Old Sep 21, 2011 | 03:22 PM
Weiboy718's Avatar
Weiboy718
baking the lights with the wiring harness is fine. You made a big mistake by placing the entire light on a metal pan. I bake all my lights with the wiring harness intact and never had an issue.
Old Sep 21, 2011 | 03:24 PM
eksigned's Avatar
eksigned
I can't thank all of you enough -- you've all been incredible. thanks very, very, very much...!!!
37
Oct 17, 2020 11:12 AM
04G35NYC
Jul 19, 2016 01:42 AM
Awgd8
Sep 30, 2015 06:22 PM
VIVID
Sep 27, 2015 09:45 AM
dedmanchan
Sep 24, 2015 11:25 PM
