another bad G battery
Old May 19, 2011 | 03:34 PM
gimpy's Avatar
gimpy
Went to the garage to start my G37 Sedan and found the battery completly dead, not low on juice but so dead I couldn't open the door with the black button on the handle or the fob. I got my father-in-laws car and managed to get it started with a jump. I drove around for about 15 to 20 miles to try to build up the battery and called the dealer for an appoint. for the next day. The ride to the dealer from my house is about 20 miles which I thought would bring the batt. up to full charge. The mechanic that worked on my car came to the waiting room to tell me the battery was down to about 480 amps from what should be 550 amps (I believe thats what he said). My car is an 09 that I bought in Dec of that year which makes it about 17-18 months old and it only has a little over 4600 miles. He sugjested I don't drive it enough and with all the things (computerized things) that are constently drawing power from the battery sucked the life out of it. Bottom line, he put a new 700 amp battery in it at no charge so I can't complain. Geuss I'll start driving it more.
Old May 19, 2011 | 03:49 PM
How long at a time do you leave it dormant without driving it?
Old May 19, 2011 | 03:53 PM
NJKSC27's Avatar
NJKSC27
yup happened to me about 4 times in my coupe and went through two batteries in 2 years
Old May 19, 2011 | 05:20 PM
madmax2k1's Avatar
madmax2k1
Your mechanic is an idiot; there is a TSB for the battery draining issue, I got mine replaced a couple of months ago along with an emission valve under warranty.
Old May 19, 2011 | 06:03 PM
gimpy's Avatar
gimpy
There have been times that the car sat in my garage for 4 to 6 days, not often but once in awhile. I don't understand how it did not charge itself during a 20+ mile trip to the dealers. He even sugjested I buy a Battery Tender to put on it if it isn't going to be driven for a few days. I mentioned that the bat. tender seems a bit much to maintain a charge on a almost new 40k+ car.
Old May 19, 2011 | 06:16 PM
gimpy's Avatar
gimpy
Is there a link to the TSB issue? I'd liike to make a copy of it to keep in my glovebox. At least they put in a new more powerful (700 CCA) battery without any argument.
Old May 19, 2011 | 06:19 PM
4-6 days isn't excessive. If you were leaving it for weeks at a time it might run down, but you should be able to leave it for a week and it should start right up every time.
Find all TSB's here: Knowledgebase - Service Bulletins - Infinitihelp.com Forums
Old May 19, 2011 | 11:04 PM
gimpy's Avatar
gimpy
[QUOTE=Black Betty;3139294]4-6 days isn't excessive. If you were leaving it for weeks at a time it might run down, but you should be able to leave it for a week and it should start right up every time.
Find all TSB's here: Knowledgebase - Service Bulletins - Infinitihelp.com Forums[/Q
Thanks for the help Black Betty.
rk325
Oct 13, 2015 01:51 PM
si_driver
Oct 1, 2015 09:53 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
