Anyone know if these jets are easy to aim and adjust,or should the dealer take care of it?
There seems to be a spot that is always missed on my windshield,and it usually has bird crap on it.
If anyone has tuned these jets,is it a simple screw driver job,or a pain in the butt?
Thanks all.
It's really easy, it tells you in the manual. You just stick a pin into the nozzle and move it around to aim it. You just need to move it a tiny bit in order to move the aim quite a bit.
Thanks all.
I have never fixed it on my G but i have on my mom's altima. I supposing all cars have the same method of adjusting the washer jet direction.
The way i did it on my moms car was just take a needle or a safety pin, put it into the hole where the washer fluid comes out from. and adjust it accordingly.
Thanks guys,appreciate the input.It just looked like they were fixed as 3 jets per side,but I'll give it a shot tomorrow.
This is sort of off topic, but the washer jets on Infinitis are crap. I couldn't believe how pathetic they were the first time I used them. I haven't seen that tri-pattern weak spray since I had a 91 Pontiac.
The nozzles on my 06 civic were far more impressive than ones the G, I must admit. But if you want to hear about crappy nozzle, you should see the ones on a smart fortwo. Those are the worst I've seen in my life.
