FOB key dying maybe?
Old Feb 22, 2010 | 10:48 PM
Infiniti7's Avatar
Infiniti7
When I got out of my car tonight I went to lock my doors by pressing my key like I always do. For some reason tonight when I hit lock the doors wouldn't lock for some reason and I had to hit the button about 5 times until the car locked. The key is only about 2 months old. Could the battery be going dead that fast? Why didn't it lock the first time I pressed lock like I always do you think?
Old Feb 22, 2010 | 11:50 PM
da mayor's Avatar
da mayor
when you got in the car did the key E/F logo come on the message area?
Old Feb 22, 2010 | 11:58 PM
FourT2's Avatar
FourT2
IDK, do you have tint on your car by any chance, maybe it gets in the way?
Old Feb 23, 2010 | 12:21 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
LOL , tint getting in the way
To the OP maybe these threads will answer the question
https://www.myg37.com/forums/audio-v...y-key-fob.html
https://www.myg37.com/forums/g37-sed...een-today.html
Old Feb 23, 2010 | 11:30 AM
Infiniti7's Avatar
Infiniti7
Yes I have tint on my car. Ha there is no way tint would get in the way of locking doors..when I hit the lock button the key was in my pocket I don't know if that has anything to do with it trying to lock it in your pocket?
Old Feb 23, 2010 | 11:41 AM
da mayor's Avatar
da mayor
the only thing i can say is maybe the keyfob was touching your cell phone and your cell was getting either data signal or you are on the cell phone to interfere w/ your key....
did i get it right?
Old Feb 23, 2010 | 12:27 PM
terrycs's Avatar
terrycs
Could be any number of things. Try using the other ikey to narrow down the possibilities.
Can I ask why you used the ikey button to lock your doors? IMO, it's easier to push the button on the door since you hand is already on there to close it.
No need to dig through your pockets to push the button unless you are too far away from the car to push the door button.
Old Feb 23, 2010 | 03:53 PM
sonicloud's Avatar
sonicloud
Need to use the key fob to arm the factory alarm.
Old Feb 23, 2010 | 04:52 PM
Arvig's Avatar
Arvig
That's not how I understand it.
Someone correct me if I'm wrong, but this is from the owner's manual. I'm cutting and pasting from Page 2-28 of a PDF file of the manual:
1. Close all windows.
The system can be armed even if the windows
are open.
2. Push the ignition switch to the OFF position.
3. Remove the Intelligent Key from the vehicle.
4. Close all doors, hood and trunk. Lock all
doors. The doors can be locked with the
Intelligent Key, door handle request
switch, power door lock switch or mechanical
key.
5. Confirm that the security indicator light
comes on. The security indicator light
stays on for about 30 seconds. The vehicle
security system is now pre-armed.
After about 30 seconds the vehicle security
system automatically shifts into the
armed phase. The security light begins to
flash once every approximately 3 seconds.
If, during this 30-second pre-arm
time period, the door is unlocked, or the
ignition switch is pushed to ACC or ON,
the system will not arm.
That to me tells me that using the button on the door handle will lock the car. The PDF I have is for both the Coupe and Sedan, as is the paper book in my glove box.
hispeed-lowdrag's Avatar
hispeed-lowdrag
definitely check this, a cell phone can mess with your key fob (just keep them in different pockets)
did i get it right?
I TOTALLY agree!! just use the buttons on the door...
aaaaaaand NO. you dont. the factory alarm automatically arms itself when the doors are locked for >1 min. it has nothing to do with which method is used to lock the doors.
Old Feb 23, 2010 | 09:47 PM
sonicloud's Avatar
sonicloud
my bad, I mean factory impact sensor.
Old Feb 24, 2010 | 12:30 AM
lokitiw's Avatar
lokitiw
When I picked up my '10' the dealer told me that the motion alarm may or may not set with the door buttons and to use the key fob to insure it is set.
Old Feb 24, 2010 | 12:39 AM
DownstairsDave's Avatar
DownstairsDave
Must have been the pocket sensor. Lord knows what would happen if you locked your keys in your POCKET!
Amaadkhan2k
Oct 4, 2024 01:20 PM
philttz
Feb 17, 2016 11:26 AM
MrRiv
Sep 29, 2015 04:59 PM
AMai1215
Sep 13, 2015 12:59 PM
