Something weird happened
Old Feb 15, 2010 | 02:03 AM
IgS's Avatar
IgS
Was driving my 09 g37x sedan around 40-45mph, then pressed the gas to speed up and the car started to feel like its stalling and rpms wouldnt go above 2.5k. Felt like the MAF failed, but no CEL. Pulled over to the side of the road, turned off the engine and then turned back on - felt like it had no power, every time i rev it goes to 2.5k and the car shakes a bit and thats it. Turned off the engine again - waited a minute - turned back on and everything was fine....
My thought was that maybe i pressed the gas right as it was shifting gears or doing something else and i "confused" the ecu somehow.. but thats a complete guess.
anyways, this was a one time happening and hope it stays that way.
Anyone ever experience anything like this or have any input on this?
Old Feb 15, 2010 | 04:10 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Have your dealer check it out for error codes.
I what seems to be a similar problem
https://www.myg37.com/forums/g37-con...-the-vert.html
Old Feb 15, 2010 | 05:55 PM
dkmura's Avatar
dkmura
20 Year Member
You experienced the ECM shifting to 'limp mode'. When retain codes or parameters are reached, the ECM may determine that continued high RPM operation may be dangerous to the longevity of the VQ37VHR. By limiting revs and output, it may limit potential damage.
The ECM holds any codes in memory (even if it doesn't trip a CEL), so report that to the dealer and have them check it under warranty.
Old Feb 15, 2010 | 06:26 PM
IgS's Avatar
IgS
Thanks, ill take it to dealer and check it out. Im guessing i should install the stock intakes just to be safe. (i have Injen SRI) < is this something that might have been the cause?
fuzzed
Aug 21, 2020 09:35 AM
linvbro
Aug 22, 2016 01:25 PM
Prometheus
General Tech Questions
Nov 9, 2015 01:23 PM
parkern
Oct 1, 2015 10:15 PM
ajosowiecky
Sep 30, 2015 12:15 PM
