Jacked up smell coming from air conditioning vents
Old Jul 22, 2009 | 11:39 PM
Nocturnal's Avatar
Nocturnal
How do I get rid of it? I'm guessing it's moisture build up but man it started to really get smelly.
Old Jul 22, 2009 | 11:41 PM
aliiin's Avatar
aliiin
BMW Defector
how many miles do you have on the car? how long have you had the car? you might want to change your in cabin air filter.
Old Jul 22, 2009 | 11:44 PM
DJ Hellfire's Avatar
DJ Hellfire
There is a few ways you could fight it. First, try replacing the cabin air filter. Then find a can of frigi-fresh and spray it into the interior air duct intake through the cowl near the wipers. The others may not be practical but you could remove the blower motor and try cleaning inside the ducts. And you can also try getting to the bare heater core and evaporator. The evaporator is actually the source of the smell. All the moisture and bacteria settles on it. The frigi-fresh and cabin filter should do the trick. Although, I can't really stand the smell of frigi-fresh, but I guess it's better than that aweful stinch!
Old Jul 22, 2009 | 11:45 PM
Nocturnal's Avatar
Nocturnal
There is roughly 1800 miles and I always use the a/c. It's been on recycle mode so I just read in another thread that putting it onto the fresh air cycle may help.
Old Jul 23, 2009 | 12:07 AM
DJ Hellfire
Keeping it on recycle causes the smell to happen faster. Putting it on fresh now without treating it most likely will not help much. At the very least, the smell will be there on cold starts and go away after about 1 minute of fresh air use.
superjoey
31
Mar 22, 2023 11:56 PM
lobuzz311
16
Oct 17, 2016 08:59 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
