G37 Sedan Moonlight White key hole delete
Old Feb 27, 2009 | 11:11 PM
REKKO's Avatar
REKKO
Ordered the part from Metro Infiniti on Wednesday and picked it up Friday morning. Took about 5 minutes to install.
After reading on this subject and looking at all the pics of different install methods, I installed it with ease. I think a lot of people are avoiding this install because of the fact that if something happens with the remote battery they think they will be stuck. Wrong! There is no need to take the whole lock or even open the door at all!
After taking the MW plastic cap off the dummy piece it came with I then proceeded to lock the car, pull the driver's side handle all the way out and insert a microfiber towel in place to keep it open while working. I then taped up the area I would be working around with blue painter's tape so I wouldn't scratch anything with the screwdriver needed to do the job. I found the best way to pry off the driver's side key hole cover is from underneath the handle. After messing with it very carefully for about 2 minutes I succeeded separating the part. Once you pop the cap you will have to wiggle the piece off with very little force. Take the new cover and pop in on the key hole area and you're done!
I did this all without opening any doors. Very straight forward removal and install. I feel the only very important thing to remember is to cover the door up with enough blue tape in case the screw driver slips.
Old Feb 27, 2009 | 11:17 PM
NismoVQ37's Avatar
NismoVQ37
Not bad fer 5 mins
Old Feb 28, 2009 | 12:38 PM
Comiha22's Avatar
Comiha22
REKKO - That looks sweet. How much were the set of Covers?
Old Mar 1, 2009 | 12:21 AM
REKKO's Avatar
REKKO
It is actually the passenger's side door handle part, but works for the driver's side. Total cost was $31 with tax. Here is a pic of the part (MW). Ask for Osmundo in parts at Metro Infiniti in Monrovia.
Old Mar 1, 2009 | 05:50 PM
da mayor's Avatar
da mayor
it's always a cheap install job.... your car looks nice and clean
Old Mar 1, 2009 | 06:15 PM
08g37's Avatar
08g37
does moonlight white have pearl in it?
Old Mar 2, 2009 | 01:39 AM
REKKO's Avatar
REKKO
It has kind of a metallic top coat. This is the same color used on the M from Infiniti. It looks amazing all cleaned up. Very happy with my color choice.
Old Apr 13, 2009 | 11:45 AM
babyjig's Avatar
babyjig
I did the same thing to my black G37.......Unfortunetly I slightly scratched my car under the handle in the process. I put enough tape but I was just to forceful and the screwdriver went right through the tape. Its a tiny scratch but it bugs me.
slowbird
Aug 3, 2023 07:54 PM
superjoey
31
Mar 22, 2023 11:56 PM
tom_lom
Jun 30, 2021 07:52 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
