MotiveMag: 2009 Infiniti G37xS (+08 G37 Modded Coupe by Stillen & MOMO)
Old Aug 25, 2008 | 10:13 AM
albeik's Avatar
albeik
The "37" means that for 2009, Infiniti's smallest sedan has played catch-up with its coupe counterpart and has ditched its 3.5-liter engine for a more technological 3.7-liter producing 328 hp and benefiting from a wider powerband thanks to Variable Valve Event and Lift. Unlike most systems that only alter timing, VVEL uses both hydraulically-controlled variable valve timing and electronically controlled variable valve lift on the intake side, which improves performance, response, emissions, and fuel efficiency. A relatively low increase of 22 hp might not seem worth all the trouble, but overall, the engine doesn't feel as coarse as the outgoing unit, a long-running complaint of Infiniti's otherwise brilliant VQ-series. The power increase is also noticeable throughout the rev range, not just at its peak, and EPA test figures should be up one mpg over the previous G sedan, thanks to a new seven-speed automatic transmission.
http://www.motivemag.com/pub/feature...-Stillen.shtml
Old Aug 25, 2008 | 10:21 AM
Gthirty7's Avatar
Gthirty7
the red g looks nice
Old Aug 25, 2008 | 11:28 AM
blue_z's Avatar
blue_z
The sport-packed G37 not only gets a new wheel design, but also the coupe's bigger brakes. Squeezed by four-piston calipers up front and two-potters in the back, the rotors measure 14.0 inches and 13.8 inches, respectively.
so i'm assuming that the 19" coupe's wheels will fit on the new sedan?
no matter how hard i try, I can't get myself to like those new wheels
Old Aug 25, 2008 | 11:56 AM
B L U E S L A T E's Avatar
B L U E S L A T E
Coupe 19s will fit just fine.
Old Aug 25, 2008 | 12:33 PM
Buddy Revell's Avatar
Buddy Revell
I wonder what the curb weight of the sedan will be?
Old Oct 2, 2008 | 01:18 PM
SubaruFlamingo's Avatar
SubaruFlamingo
Yeah, would be nice to stay the same or lose a bit of weight.
Old Oct 2, 2008 | 01:46 PM
Keng's Avatar
Keng
The Rim doesn't look all the bad...
Old Oct 2, 2008 | 02:07 PM
myk1013's Avatar
myk1013
Sedan wheels suck!!
GW330
Feb 2, 2024 05:41 PM
e92ry
Dec 31, 2015 08:02 PM
BANNISTER
Dec 10, 2015 04:14 PM
TakmaN
Aug 8, 2015 07:47 PM
Ali K.
Aug 5, 2015 11:49 PM
