08 to 2011 seat swap
Old Jul 8, 2025 | 10:32 AM
clapped.vqhr's Avatar
clapped.vqhr
i was looking at doing an interior swap from tan to black and was wondering if seats door panel and the trim on the bottom of the door where it reads infiniti from a 2011 g37s coupe is compatible with my 2008 g37s coupe
Old Jul 8, 2025 | 12:07 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Everything should be a direct swap EXCEPT the seats. While 2010+ seats will physically bolt right in, there are wiring differences- specifically with the seat heating system- that IS NOT compatible with 2008/2009 models. If you do not care/ use/ need the heated seat portion then you should be good to go.
Also, there might be some wiring differences when it comes to the ADP system. A check of the different FSM's should verify same.
Old Jul 8, 2025 | 03:08 PM
clapped.vqhr
ok thank you sir. will the door panels be transferable as well?
Old Jul 8, 2025 | 04:01 PM
ILM-NC G37S
Everything in the interior is interchangeable including the door cards (panels). The only "hiccup" are the seat electrics which, with a little work, can likely be addressed.
mousexxl
General Tech Questions
Sep 14, 2023 12:15 PM
G3709876
Oct 31, 2022 03:11 PM
PerryBaxter85
Feb 20, 2021 09:17 AM
G37s BK
Jun 10, 2018 01:15 PM
Rybitron
Aug 10, 2015 10:21 AM
