2008 G37s Coupe Driver Seat Swap
Old Oct 29, 2022 | 11:29 PM
G3709876's Avatar
G3709876
I recently swapped out my stock 2008 G37s coupe (Automatic) driver seat with another 2008 G37s coupe (Manual) diriver seat. All seat functions work fine but the memory seat buttons on the driver side door are not working. They do not light up (when I press 'Set'). I've tried disconnecting the battery, performing a sync (turn car to ON position, open and close driver door 3-4 times), driving the vehicle for 3+ miles but nothing works. I still can't get the memory seat buttons to light up and work. They were working before I swapped the seat out. Does anyone know if there is a reset that I have to perform? Any help is appreciated.
Old Oct 30, 2022 | 12:26 AM
iCrap's Avatar
iCrap
you need to swap the white box under the driver seat. the boxes actually differ MT to AT (they are labeled)
Old Oct 30, 2022 | 02:59 PM
G3709876's Avatar
G3709876
Oh i didn’t know that, and that will make the memory buttons work and light up again? Also, my second issue is the ‘Intelligent Key’ warning light turns on now whenever I shift the car into park. It goes away when the car is in drive. Is this also, related to switching the box under the seat?
Old Oct 30, 2022 | 06:07 PM
iCrap's Avatar
iCrap
Yeah, that will make the memory work again. I don't know about the intelligent key warning, because I didn't have that issue when I swapped the seat but maybe.
Old Oct 31, 2022 | 03:11 PM
G3709876's Avatar
G3709876
Thank you so much for the information, it saved me so much time. I swapped the box over and it worked.
Zappy44
Sep 2, 2022 01:17 AM
2010g-ride
Oct 14, 2013 12:15 PM
cyberone28
Aug 23, 2013 11:50 AM
agentzero
Feb 16, 2010 05:55 PM
prutkows
Jul 20, 2008 05:01 PM
