AC pressure relief valve needed
All I need is a pressure relief valve for the AC compressor on my 2008 G37, I do not want to buy a new compressor.
Can anyone send me in the right direction to find one?
I was under the impression that on most modern AC compressors the pressure relief valve was internal to the unit itself?
What are your symptoms/ where exactly is the leak- if there is one?
That sad, Nissan does not sell ANY parts for the compressor (pressure relief valve or the ECV) for that matter- at least not on any catalog that I searched (US/ JDM/ EUC). You can try getting the model number off of the compressor (should be Valeo DCS-17EC) and try 'googling' for options.
You would be better off just replacing the compressor. Yours is, at least, 17-years-old. The new unit would have fresh seals, springs, bearings, ECV, etc. Even if you found replacement parts, you would still have to evacuate the system, disconnect the refrigerant lines, remove the compressor and so on. Put a new unit on and call it a day- but that just my 10¢.
Thanks
Sure, they make more money selling the whole compressor and I just hope the valve fits, if need be will visit a used car parts lot and score a compressor for 50.00 and just use the valve.
Thanks
Thanks
