AC problems
Old Oct 10, 2024 | 06:35 PM
tec's Avatar
tec
AC problems
Im having trouble with my ac again
bought the car 4 months ago, when i got it ac condenser/radiator wasnt working, so i initially thought that was why ac wasnt working. ive had the condenser replaced, and ac worked for a week then it stopped working. Took it back and they said it was a leak in the pipe, it worked again for about a week then stopped working.
so far ive replaced cabin air filter, ac condensor/radiator engine fan assembly and module, engine air filter, had ac refilled, and o-ring for the seal
had a buddy double check and he noticed these issues
compressor is running all the time when ac is on, does not cycle on and off
Low side pressure was high, high side pressure was normal
the lines werent cold/hot
he said the mechanic might not have done a vaccum properly, or it could be something in the compressor is bad
i found out later that the mechanic used the canned freon you can get from stores, , i dont know if it causes issues or not.
checking online, it could be compressor clutch, a leak, or possibly since a vaccum wasnt done on ac, it could have air in the pipes
tec
Sep 4, 2024 08:47 AM
superstee
General Tech Questions
May 4, 2022 09:28 AM
the dreame
Apr 9, 2017 10:30 AM
bat6wc
Sep 30, 2015 09:31 PM
jbusbygbtc
Apr 17, 2013 09:05 AM
