A/C Compressor replacement
Old Jun 6, 2018 | 08:31 PM
Mrfudge's Avatar
Mrfudge
I'm having my A/C Compressor changed this Sunday because I've been without it for some time and now it' the summer time in TEXAS, is there anything else I should consider fixing in terms of my A/C? It stoppd working while I was driving from the airport, I would turn it off and turn it on and the turn it off and the last time I turned on and noticed the air was getting warmer to the point it was blowing heat.
Old Jun 6, 2018 | 08:42 PM
soundkillr's Avatar
soundkillr
You sure it's just not low on charge? When ac systems are low on charge they will operate only in very short bursts, then not at all. It's a safety system designed to keep the compressor from locking up due to lack of charge and oil.
Check the ac pressure. If low, add the correct amount of r134 and see if the compressor will deep cycle and get cold.
Old Jun 7, 2018 | 05:37 AM
Surfnazi's Avatar
Surfnazi
Freon will be low when there is a leak. I'd check for leak before you replace the compressor
RAVSPEC
Brakes/Suspension
Jun 21, 2018 01:10 PM
Styln_Kwak
Nov 15, 2016 05:08 PM
gman69
General Tech Questions
Oct 3, 2016 05:50 PM
