G37 cooling issue
Old Sep 21, 2024 | 08:21 PM
im just yousef's Avatar
im just yousef
G37 cooling issue
Hello guys I had some questions about my 2009x g37 coupe I had a leak on one of the hoses so I took it off and drained the coolant and rebelled the system but after the car was on for 30 - 40 minutes 1k-2k-3k revs to bleed the system I realized hat the fans never came on and the coolant and gas gauges stopped working the gas went to empty and the coolant temperature even after 2 hours was still at operating temperature even though the car was off after that I realized that the battery was dead and couldn’t start the car, as I plugged it in the temperature gauge started to go down slowly and the gas gauge went back to the correct quarter tank not sure were the issue is.
- my engine was replaced 6 months ago and I didn’t drive it till now
- i was able to spin both fans freely they weren’t seized at all
- my friend was able to turn both fans on manually with a scanner
aftsr the first day the t bolt clamp started leaking again but I tightened it and it was ok but it seems like the coolant is trying to push out of the pipes
- the coolant takes a really long time to heat up at the top and bottom hoses!
ipdm test doesn’t work at all I tried multiple times and nothing happens!
please let me know if you might know how to fix it! Thank you and thanks for reading everything sorry it’s so much!
iigghG
General Tech Questions
Jan 7, 2024 12:07 AM
Trigga0
Oct 10, 2023 08:41 PM
Anthony Rud
Oct 3, 2020 06:06 PM
Bossman
Oct 14, 2017 08:25 PM
