How do I access the fuel tank fuel sensor in the coupe?
I am having issues with my fuel gauge and watched several videos showing how to remove the fuel sensor located under the rear seat behind the driver and clean it. However all the videos are for the coupe. Here is an example of one of those videos:
Does anyone know of a video or instructions on how I lift up the rear seat in a coupe so I can get access to the fuel sensor? In the sedan it has 2 pull tabs under the rear seat that lift it up, but I'm not sure if it is the same in the coupe.
UPDATE: In case anyone has this same question I figured it out from this video here:
In the coupe there are no pull tabs, the bottom of the rear seat is just kept in place by 2 metal tabs. I literally just had to yank up on the bottom of the seat real hard on each side and it popped right up.
Ca428
Dec 3, 2019 05:38 AM
erich_wa
Nov 5, 2019 04:26 PM
