TPMS light on can not reset
Old Jun 28, 2022 | 10:06 AM
Brian08's Avatar
Brian08
I have 09 g37 the tpms light is on and I tried to the paper clip and never can get it to start flashing. The light came on after I added the vline from grom audio. I put the grom in the glove box.
I am looking what scan too works to give me information on the tpms. Does anyone know what I can get I am willing to spend up to 300 on multi scan tool or 100 for just for this car.
Old Jun 28, 2022 | 11:53 AM
iCrap's Avatar
iCrap
Well, I believe the TPMS module is actually behind the glovebox. Double check that you didn't unplug any wires or something like that.
To answer your other question, OBD Fusion (phone app) can read the Infiniti specific codes / BCM codes.
Old Jun 28, 2022 | 02:19 PM
Brian08's Avatar
Brian08
Thanks
I got the OBD fusion I see the check engine stuff. Do I need to purchase the advanced features to get to the tpms data?
Old Jun 28, 2022 | 06:01 PM
iCrap's Avatar
iCrap
Oh, yeah you do. It's like Nissan Enhanced Diagnostics or something.
Old Jun 28, 2022 | 10:16 PM
Ponyryd's Avatar
Ponyryd
You mean the “tap ground 6 times”? On mine it only worked if I tapped 6 times quickly, like 6 times in 3 seconds or less, lol.
Old Jun 29, 2022 | 08:30 AM
Brian08's Avatar
Brian08
Yes I tired the 6 times. I got it work 1 time and I shut the car off before I drove it. I was unable to get in learn mode again.
Old Jun 29, 2022 | 09:58 AM
iCrap's Avatar
iCrap
You can also reset it through OBD fusion once you get that extended features option btw.
Old Jul 12, 2022 | 07:15 PM
gromaudio's Avatar
gromaudio
MYG37.COM Sponsor
Try these tips:
https://www.myg37.com/forums/d-i-y-i...-for-free.html
Old Jul 13, 2022 | 11:04 AM
rotarymike's Avatar
rotarymike
Moderator in Moderation
My money is on the box being unplugged or partially plugged - when you remove the glove box the TPMS box is bolted to it. Check ALL connections. It shouldn't lose wheel sender memory from being unplugged and reconnected.
Old Jul 15, 2022 | 10:10 PM
AdamBritt's Avatar
AdamBritt
I had the same issue after installing my VLine. I didn't remove the glovebox lid to remove it so it shouldn't have been the TPMS receiver getting unplugged. I did eventually replace the air filter so while I was in there I re-plugged everything and that seemed to do the trick. Maybe the receiver connector is really sensitive or something.
Old Nov 8, 2022 | 06:20 AM
garnerfor's Avatar
garnerfor
If your TPMS light remains on after inflating the tires to the proper pressure, try these steps: Drive the car at 50 mph for about 10 minutes. This should reset the tire sensors, and the next time you start the car the TPMS light should be off. forpc.onl youtube vanced for pc
SwissCheeseHead
Feb 24, 2013 05:17 PM
csnpsu
May 13, 2010 12:09 PM
Jan 4, 2010 10:23 PM
Skyline-LEXY
Feb 19, 2009 11:49 PM
