G37x rear diff swap
Old Apr 10, 2022 | 08:06 PM
Bailey37's Avatar
Bailey37
G37x rear diff swap
Hey everyone, i have a 2013 G37X 7AT that i have wired on switches for the option to bypass the AWD solenoid aswell as the brake signal that allows me to only power rear wheels but i can only do one wheel peels.... My goal is to keep the same 3.3 ratio if at all possible so i dont have to mess with front diff but i want to be able to light up both rear wheels. If someone could point me in the best direction it would be greatly appreciated, cheers!
Old Apr 11, 2022 | 06:07 AM
The Pope's Avatar
The Pope
Something like this might interest you: https://www.z1motorsports.com/z1-pro...f000ce841017e4
Do your research and select which option is best for you.
Old Apr 11, 2022 | 11:01 AM
BULL's Avatar
BULL
Moderador
So from my research into the YAW bypass, I learned thanks to Frank @MotorvateDIY that the 7at gives the car a type of electronical LSD by braking the faster spinning wheel which will give you a LSD. By dissabling the Brake input you skip these and revert to Open Diff.
You should try to disable just the AWD to see if it goes to ELSD.
FYI I just read up on the Q50 groups of a member that installed a rear Z1 LSD and had some issues. Car is a bit slower off the line, over all decent results.
Old Apr 11, 2022 | 07:24 PM
Bailey37's Avatar
Bailey37
I originally tried out the awd switch first without the brake switch but it has a safety mode where it kills power when it senses the accelerator and brake are being pushed at the same time :/
Is there another way i could bypass this safety mode without turing the brake signal off? I would love all the suggestions i can get, i promised myself i wouldnt modify the car until it was paid off and since i do so this past december, im chompin at the bit lol, thanks again
Old Apr 11, 2022 | 07:28 PM
Bailey37's Avatar
Bailey37
Thank you very much, this is my best bet so far from what ive read but its hard to get a solid answer out of some of the guys on here. Very much appreciated!
Old Apr 12, 2022 | 06:00 AM
The Pope's Avatar
The Pope
@Bailey37 did you see this thread or is this what you did?: https://www.myg37.com/forums/d-i-y-i...wd-switch.html
Old Apr 12, 2022 | 06:17 AM
Bailey37's Avatar
Bailey37
Thats exactly what i did, but i cut the orange wire instead of green and i haven't had any fuse related issues. Provided i turn the car off before engaging the switch
Old Feb 23, 2023 | 10:49 PM
G37xFreebird's Avatar
G37xFreebird
Did you ever find a solution? im currently running into the same issue as you lol. I saw another way to get rid of the brake sensor by cutting a pink wire connected to the fuse box not sure if that would fix the issue tho.
Old Feb 23, 2023 | 10:51 PM
G37xFreebird
Sorry i made another message for this I also saw that the g37xs comes with a "VLSD" according to another person on this forum (tbh not sure if thats true) but if anyone knew that would be awesome too! im sure a g37xs diff swap wouldnt be too expensive and should be pretty plug and play
Heres a forum related to this same idea https://www.myg37.com/forums/engine-...-on-awd-g.html
Old Feb 23, 2023 | 11:44 PM
Bailey37's Avatar
Bailey37
Originally Posted by G37xFreebird
Did you ever find a solution? im currently running into the same issue as you lol. I saw another way to get rid of the brake sensor by cutting a pink wire connected to the fuse box not sure if that would fix the issue tho.https://www.youtube.com/watch?v=1h6gTzGquOg&t=314s
I ended up wiring a "kill switch" into the pink wire aswell, but it only lets me do one wheel peels :/ hence the idea of the lsd swap, i will deffinately look into those links you sent, thank you very much
Old May 23, 2023 | 06:58 AM
Jah37x's Avatar
Jah37x
it seems like it should be plug n play but the flanges for the driveshaft are different so it would require some modification as you can’t just hold another flange to it
Old May 23, 2023 | 12:03 PM
socketz67's Avatar
socketz67
Community Builder
I will there was an easier means to replace the Ring and Pinion in the stock VLSD to achieve a higher gear ratio. Seems that replacement of the pumpkin (6MT or prior gen G rear diff) with modifications to the drive shaft may be the only option unless I am missing something.
G3727
Jan 7, 2021 03:54 PM
MyG3_7
Sep 27, 2020 11:13 AM
Mattlorentzoe
14
May 26, 2018 09:48 PM
91dx
Aug 1, 2016 10:46 PM
ged1067
Dec 20, 2009 09:44 AM
