Bad Wheel Bearing?
Old Nov 12, 2021 | 07:26 PM
recones's Avatar
recones
Bad Wheel Bearing?
Just got my car back from Europe where I've decided it needed some TLC after the horrible roads over there.
Does this sound like a bad wheel bearing? Uploaded to YouTube.
https://youtu.be/uhSOAj1_Cfs
Old Nov 12, 2021 | 11:32 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Seems a bit dry... Should spin freely and smoothly.
Old Nov 13, 2021 | 09:03 AM
SonicVQ's Avatar
SonicVQ
That bearing is done... When you spin a good bearing, it is almost noise free.
As Jsolo mentioned, it sounds dry (no grease) and seems a little tight.
From where you are, remove the wheel speed sensor, the 4 bolts, and use a slide hammer to pull it out of the spindle.
Old Nov 13, 2021 | 09:07 AM
recones's Avatar
recones
Thanks for the reply guys!! I figured this was the case.
Old Nov 13, 2021 | 01:42 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Went through this with the accord. It wasn't as bad as in your video.
Although only one was in bad shape, they did replace the other side too. Seems right to me. The rears on the accord are easy. Fronts more involved. Looks like you're at least half way there with the brake parts removed.
tagxtreme
G37 Convertible
Jan 8, 2019 03:05 PM
Omar_Elharis
Jan 2, 2018 03:25 PM
peterso2
Jul 4, 2015 01:09 PM
SlateBlue G
Apr 19, 2012 11:58 PM
HappyG
Sep 16, 2011 12:18 PM
