2010 G37S Clutch Master Cylinder Removal
Old Apr 13, 2021 | 03:38 PM
ggold's Avatar
ggold
I have read a few threads and not sure the easiest way to allow removal of the CMC. 1. Remove the CMC studs holding to the firewall 2. Remove LF wheel and bolts of ABS module and move it slightly to allow CMC removal 3. Remove the brake lines from the ABS, remove entirely, (install and bleed all brakes upon sucess with CMC install.
Old Apr 13, 2021 | 11:08 PM
ggold's Avatar
ggold
I did a dry run at the task of CMC and CSC removal and the CMC looks promising based on tricks provided. Issue is, the CSC removable from side of trans, or will the trans be needed to be removed.
Old Apr 18, 2021 | 10:37 PM
ggold's Avatar
ggold
Being a new comer, what is the anticipated time for a response.
Old Apr 18, 2021 | 10:39 PM
ggold's Avatar
ggold
What is the difficullty factor in removing the transmission from a 2010 G37S? Any tips and if I take it to a shop what is the ball park labor time for CSC removal and replace?
LAMOKI FLARE
Aug 5, 2019 07:46 PM
Tiagofloater
Aug 14, 2017 07:20 AM
GP4L
21
Nov 20, 2016 02:12 PM
BluestickG
Oct 25, 2011 11:23 AM
clawlan
Jul 27, 2010 12:01 PM
