Steering wheel stiffening
Old Mar 12, 2021 | 10:29 PM
Gok37's Avatar
Gok37
Hello everyone,
My 2013 coupe recently started having the wheel stiffen up when I am at low rpm, reversing or turning my wheel at a stop. It only happens when I turn my wheel and a sound is coming from my pump. The car drives perfectly when cold starts but after it warms up the problems start happening I don't know what to do I changed my power steering fluid and bleed the steering fluid and still have the same situation. What do you think is the problem? and how would I fix this problem?
Old Mar 13, 2021 | 10:27 PM
crookncastle's Avatar
crookncastle
highly likely your p/s pump is going out.
Old Mar 15, 2021 | 09:41 AM
SonicVQ's Avatar
SonicVQ
I agree with crookncastle...
Either get a new/rebuilt pump or a much lower cost, get a used one from ebay or the local scrap yard.
Old Mar 15, 2021 | 08:44 PM
BULL's Avatar
BULL
Moderador
There is a two wire connector under the car that goes to the PS rack. This is your steering assist wiring, 90% of folks rip it out unknowingly. IF this is not damaged then you are having pump issues.
Old Mar 15, 2021 | 10:33 PM
Epiphany's Avatar
Epiphany
99% the pump. Mine went out a few years ago. If you blip the throttle while stopped does the steering get easier?
Old Mar 16, 2021 | 12:10 AM
crookncastle
you are referring to the speed sensitive steering valve on the p/s rack. the poster is complaining about noise from the pump and lack of assist. the speed sensitive steering valve will not cause the pump to make noise.
bull--->"There is a two wire connector under the car that goes to the PS rack. This is your steering assist wiring, 90% of folks rip it out unknowingly. IF this is not damaged then you are having pump issues."
Old Mar 19, 2021 | 10:55 AM
GLife14's Avatar
GLife14
What's with all these premature steering pump failures?
Old Mar 21, 2021 | 07:58 PM
takemorepills's Avatar
takemorepills
My 2014 occasionally does this also. Began at 45K miles.
At least it's likely a pump and not the rack.
Old Mar 27, 2021 | 06:47 AM
x818ray's Avatar
x818ray
Right??? I'm on my 2nd rack/pinion and 3rd steering pump in 8yrs...All warrantied. My first pump failed at 15k miles btw... Just bought my 4th pump today ( HITACHI PSP0013) from Rockauto. I'll be installing that myself since my 8yr/120,000 mile Elite warranty expired january 1st. My car is currently at 98,000 miles. FYI...!!! I'm on a roll lately....6 weeks ago I had to replace my 7 speed transmission after a failed (drain/fill/pan drop). Pretty straight forward job if you have the right basic tools. I blame valvoline maxlife ATF. Last week I replaced Bank A valve cover gasket/tube seal after discovering oil on one of my spark plugs when changing them a few months ago.
Old Jun 16, 2021 | 12:38 PM
ZzBloopzZ's Avatar
ZzBloopzZ
Whoa! I'm so sorry you are having all those troubles.
Could you talk more about the drain/fill/pan drop? I was about to do that for the first time on my 2013 G37X Sedan next weekend. I was also planning to get the Valvoline Maxlife ATF as everyone in that thread said it was fine.
How exactly can you tell when the power steering pump is failing? I recently had a 2021 Audi Q5 as a rental for a 1500 mile road trip and so when I came back to my G in the airport parking lot after it being parked for 10 days the steering wheel felt incredibly stiff. Even a week later I still feel it is stiff but not as much as I remembered the first time coming back from the flight. Can't tell if it is me that I got used to the electric steering of the Audi for if my pump is going bad. There is plenty of PS fluid and I changed out the fluid 1.5 years ago. Also, when I start car I do see all the fluid moving inside the canister and there is no sound coming from the pump that I can hear. Car is at 66k miles.
Appreciate your input!
Old May 8, 2023 | 01:34 AM
Johnny_Cali's Avatar
Johnny_Cali
did that brand power steering pump end up going good for you?!
Old May 8, 2023 | 09:01 PM
x818ray's Avatar
x818ray
hey. it never got installed. i did a complete drain/fill that took care of the whine and stiffness when turning. the part itself is an oem pump from factory (HITACHI). nissan re-brands it as their own.
AdamBritt
12
Mar 16, 2020 03:05 PM
G37ampandmusic
Jan 9, 2020 04:08 PM
sharmelan
Jan 12, 2016 02:37 PM
kkokko
May 31, 2009 01:56 PM
leeladisky
Apr 27, 2008 01:34 AM
