Need expert advice ASAP
Old Nov 19, 2020 | 06:12 PM
mummy2's Avatar
mummy2
Thanks for telling me to double check all the fuses. It was the 10a fuse that says Elec Parts (IGN) in the drivers footwell. It's the fuse which controls the environmental controls and the shifter lockout. That's why I never bothered to check it the first time since it's so non-descriptive. I'm just now seeing that it has happened to others on here too. Noticed when I put the negative cable back on that it was loose on the terminal. Had it tightened all the way but I can still spin it on the terminal by hand. Could that have caused the fuse to blow? And I take it that's a sign that it's time to get a new battery?
Old Nov 19, 2020 | 06:22 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Glad you are up and running and that the solution was a easy fix.
Thanks for the update.
Old Nov 22, 2020 | 11:28 PM
JavierV's Avatar
JavierV
Ok thanks for the info, imma look at the fuses again. I checked them the other day and they all looked good but maybe i missed one. And besides my shifter being stuck in park my tailights arent working also.
Old Nov 22, 2020 | 11:41 PM
mummy2's Avatar
mummy2
My taillights never went out though. Just throw a new 10 amp fuse in there and double check your battery cables and pray that solves the problem. https://carkiller.com/scottykilmer/q...es/#post-17954
Old Nov 22, 2020 | 11:48 PM
JavierV's Avatar
JavierV
Just about all of your current symptoms point to a issue with the AC Amplifier which relies heavily on CANBUS. As SonicVQ stated, the code U1001 has priority. Think of it in terms as being "the internet is down."
Double check all of your fuses. Every. Single. One. Then, check any and all ground connections you can find- ensure they are clean and tight (especially those under the hood). I hate to ask, any chance of water leaking into the cabin? Any electronics added/modified?
From the FSM- same diagnostic protocol- check wiring:
Because this issue popped up "out of the blue" makes me believe it is something minor.
i installed a fog light to the taillight and recently took off, when taking off i think there was a short or something because after than the abs, vdc and sip lights came on and car is stuck in park as well, i checked fuses and they look good might have to double check them again, but any idea o what else it could be, any help will be appreciated, thanks
Old Nov 22, 2020 | 11:51 PM
JavierV's Avatar
JavierV
ill definitely check the battery tomorrow morning and for the fuse, i changed both 10 amp fuses for the tailights and still didnt come on, the emergency lights, turn signals do work just not brake lights
Old Nov 23, 2020 | 12:02 AM
mummy2's Avatar
mummy2
I meant the 10a fuse that says Elec Parts (IGN) in the drivers foot well. That fuse controls a bunch of stuff that aren't even remotely related to each other.
Old Nov 30, 2020 | 01:04 PM
mummy2's Avatar
mummy2
So, what was the issue?
Old Nov 30, 2020 | 02:47 PM
JavierV's Avatar
JavierV
it was the damn fuse bro🤦‍♂️
Dmwall12
Jun 6, 2020 04:48 PM
Neddy_G37
Oct 5, 2018 05:27 PM
lausellduane
Jan 28, 2018 04:50 PM
beto4632
Sep 3, 2014 07:33 AM
