08 g37s coupe manual
I’m stuck with my car. I have had a p0340 code camshaft sensor bank 1 position A. I changed the sensor, checked the wiring harness, replaced the timing chains and camshaft sprocket, after a long run with my old engine. I replaced my engine and still the same code. I just changed my ecu and still the same problem. I don’t done what else to do
If you replaced the engine and the ECU then your issue has to be somewhere in the wiring. The odds that both engines and both ECU's exhibiting the same codes is incalculable.
Double check all of your wiring harnesses, grounds etc.
askxnga
Aug 30, 2019 09:30 AM
aznwash3wboi
Apr 3, 2013 12:04 PM
