Y pipe damaged
Old Sep 24, 2020 | 11:44 PM
Himalaya's Avatar
Himalaya
Y pipe damaged
My stock y pipe has the mesh area which is falling apart. Its making a rattling/metal noise when i increase throttle. The dealer said its corroded. Are there cats on the y pipe? I have an inspection coming up. Will I pass inspection? They do visual inspections with cameras under the car. Is the mesh on the Y pipe cats as well?
I am looking into aftermarket exhausts now. I am ready to purchase the fast intentions full exhaust as i already have their high flow cats. But they don't even have a y pipe, its just two straight resonated pipes. I live in New Jersey. Would getting this exhaust cause me to fail inspection? They don't smog test here but they do a visual inspection.
Old Sep 25, 2020 | 06:12 AM
The Pope's Avatar
The Pope
The Y Pipe bolts to the CATs, so "visually" it "should" pass inspection as far as the CATs are concerned.
If there are holes in the exhaust pipe, that "could" cause you to fail the inspection, but if there are no holes, you "should" be good.
As to the fast intentions full exhaust, well, it does state that it's a full exhaust, so it should pass inspection.
MNfiniti
Intake and Exhaust
Dec 28, 2020 10:24 AM
steveng37
Intake and Exhaust
Apr 18, 2020 07:14 PM
rob145
Intake and Exhaust
64
May 5, 2016 03:36 PM
Vu37
Intake and Exhaust
22
Mar 12, 2010 05:19 PM
