Window Deflectors 2010 G37x Coupe
Old Dec 27, 2018 | 09:12 AM
br00se's Avatar
br00se
Any one know where I can get window deflectors for 2010 G37x Coupe? I had my battery replaced last night and now my driver side window will not automatically raise to full closure. Now, there is a small gap whenever I leave the vehicle. this happens on passenger side window as well, and I'm told it will cost over $1000 to replace the motor and something called a switch. So I'd rather put a window deflector to prevent rain coming in for now.
Old Dec 27, 2018 | 09:14 AM
skrolz's Avatar
skrolz
That's BS. Try this:
Old Dec 27, 2018 | 09:34 AM
br00se's Avatar
br00se
skrolz, my brother, U DA MAN!!! So it worked wonderfully on the driver side window, but did not fix the passenger side. Although, I've had the passenger side window already worked on by replacing the motor (cost $450) but mechanic says that the switch needed replaced for another $650. I only drive my G37x for work so it's just me. So I never use the passenger side window, only on rare occasions. It's always in the up position. And when on those rare occasions I need to use that side, I normally have the person exit the car and then raise the window to full closure from inside because, as you know, the window goes down a bit when exiting the car. That window doesn't automatically go to full closure.
But, thank you again. I will not require that window deflector now.
Old Dec 27, 2018 | 04:27 PM
slawek65's Avatar
slawek65
You can't install deflector on frame less window.
Old Dec 28, 2018 | 12:54 PM
Landshark's Avatar
Landshark
wrong. i had them on my Legacy GT with frameless windows - they attached above the door with 3M double-sided tape.
they may not MAKE them for the G, but its not impossible.
Old Dec 28, 2018 | 04:45 PM
jpowersjr2's Avatar
jpowersjr2
Did those windows adjust (move up/down) whenever opening or closing the door?
Old Dec 28, 2018 | 08:20 PM
takemorepills's Avatar
takemorepills
Subaru's generally don't (my wife has a 2006). The good thing is that they don't need the fine-tuning our windows occasionally need. The bad thing is they let wind noise in, but fortunately cracking the window open a bit and re-closing it reseals the window until next time the door is open.
But, back to the OP, makes me shudder to think that someone would be so quick to cover up a problem on an otherwise nice car with a stick-on doodad. I guess these cars are hitting the bottom end of the market....
Old Dec 29, 2018 | 07:22 PM
br00se's Avatar
br00se
I get what you're saying 'takemorepills', but time was of the essence and we were about to get inclement weather and I didn't want to have wet leather seats and water up to my ankles in my nice G. Skrols was a lifesaver.
Old Dec 29, 2018 | 07:25 PM
br00se's Avatar
br00se
jpowersjr2, yes they do.
Old Dec 29, 2018 | 09:34 PM
jpowersjr2's Avatar
jpowersjr2
I was asking about the Subaru's.
Old Jan 1, 2019 | 11:23 PM
mummy2's Avatar
mummy2
The kind that go on the outside and stick with tape are so cheap looking, in my humble opinion. No disrespect though. The other guy was referring to the kind that slips into the window frame. I have them for my Volvo. They come in so handy during the summer and when it's raining.
Old Jan 1, 2019 | 11:25 PM
mummy2's Avatar
mummy2
https://www.myg37.com/forums/body-in...ndow-fuse.html Try this. Turns out i had a bad fuse. Went to the junkyard and grabbed one and haven't had the problem happen again.
Old Jan 2, 2019 | 08:33 AM
Landshark's Avatar
Landshark
they looked fine. besides, it was a $25k Subaru, not a vintage Ferrari.
they kept a tidal wave of water from pouring on my arm if i cracked the window when it was raining or had water on the roof, so they were worth it to me.
inner_senna
Sep 5, 2016 11:06 AM
JDUB916
Jul 30, 2012 04:11 PM
