Why is steering feel so different between coupe and sedan ?
Old May 8, 2015 | 04:59 PM
jissolid's Avatar
jissolid
2015 G37 journey sedan is stock Goodyear eagle rs-a P225/55/r17
2013 G37 Journey coupe is stock Dunlop P225/50/r18
I did not want to cause any confusion or anything.
I noticed my sedan had a light feel and needs driver adjustment imo going straight.
The Coupe has a noticeable tight & firm feel when steering, as in more force is required to change direction. Plus does not need adjustment when going straight.
So I just thought I would ask if there was a known difference that would cause this. Like steering ratio difference but that would only apply to a sport model which neither is and was unavailable for the 2015 sedan.
My conclusion is I believe the 18"s are 8.5 and the 17"s are 7.5 the added width might be the cause of the tighter steering.
Thank you
EDIT Did not want to post again for this update. Turns out all the tires were cold 12lbs overinflated since I got the car. Correcting the cold tire pressure to the recommended amount has helped the issue I was describing.
Attached Thumbnails Why is steering feel so different between coupe and sedan ?-img_2997.jpg   Why is steering feel so different between coupe and sedan ?-img_2998.jpg
Old May 8, 2015 | 06:11 PM
Also the Goodyear RS-As are some of the most horrendous tires for a car pushing 300+ HP.
They are a minvan or 4 cyl. Camry tire.
Old May 20, 2015 | 09:17 PM
jissolid's Avatar
jissolid
Just want to update as I found a resolution. I went to the dealer for the first service. Wile there I mentioned the issue I described here prior. Turns out I needed an alignment. Alignment made a difference. My sedan has 1,500 miles and the alignment sorted out what I felt from day one. So thank you to the service department.
Old May 20, 2015 | 10:46 PM
Glad you got is sorted out, that over inflation didn't help either.
superjoey
31
Mar 22, 2023 11:56 PM
m3clubracer
Sep 11, 2016 09:01 PM
joeposter
Sep 8, 2015 04:36 PM
xpcgamer
Sep 5, 2015 09:28 AM
IPL G37
Aug 13, 2015 08:25 PM
