Help G37S Coupe has water leak - driver side coming from upper dash
Old Dec 9, 2014 | 12:02 AM
anorudo619's Avatar
anorudo619
Has someone experienced this type of leak. Is it coming from a replaced windshield or some other location. Please advise.
Old Dec 9, 2014 | 03:08 AM
vqsmile's Avatar
vqsmile
When it comes to leaking cabin, a poorly replaced windshield is always a possibility. Others I've heard of are a torn/missing/leaking grommet in the firewall area, a clogged/leaking AC condensation drain. The strangest I can recall were a flooded battery compartment and a leaking moonroof drain. Happy hunting.
Old Dec 9, 2014 | 12:36 PM
Tachyon's Avatar
Tachyon
I have, I would check under the hood behind the battery. If the grommet is loose water will leak directly onto the BCM. Have you had any aftermarket work done?
Old Dec 10, 2014 | 12:11 AM
anorudo619's Avatar
anorudo619
thanks ima look around in batt area. thanks
Old Dec 10, 2014 | 12:16 AM
SPDCRZ's Avatar
SPDCRZ
the firewall is the place to look. Where the air goes in on the plastic. That is where water likes to concentrate it self. I had it happen on the passenger side before. Just put some sealant around the grommet and I was all fixed.
Old Dec 14, 2014 | 06:37 PM
anorudo619's Avatar
anorudo619
ok brought back to citywide glass and infiniti dealer. discovered problem was the windshield driver corner caulk was off. it was replaced and my leak seems to be fixed. furthermore, infiniti reset my computer due to water coming in contact w/sensor. GtG G37S ready to roll
Old Dec 19, 2014 | 10:45 AM
GS07's Avatar
GS07
If you get a chance post a pic of the area of weatherstripping that was responsible
Old Jan 5, 2015 | 04:07 PM
Austin713's Avatar
Austin713
did they reset your BCM and everything was good to go?
Old Jan 5, 2015 | 08:03 PM
Uscroat's Avatar
Uscroat
I just had the dealer replace the gasket along the roof above the windshield. My car is a convertible but the Tech indicated that he has seen this in both coupe and convertible. It seems to have corrected the leak.
Old Jan 7, 2015 | 11:14 AM
TimWare's Avatar
TimWare
If you had water in contact with the BCM, to the point it needed a reset, then it's possible you will have corrosion on those electrical items down the road. Not guaranteed but a consideration. Be sure to make note of what was done and keep that on file.
GXXXVII
General Tech Questions
Dec 11, 2021 08:58 AM
SiKHG37
18
Sep 14, 2015 01:35 PM
pcwd
Aug 12, 2015 06:54 PM
kevinmward
Aug 12, 2015 12:09 AM
JakeG37
Aug 3, 2015 09:28 PM
