mesh grill to tacky?
Old Nov 30, 2016 | 12:38 AM
Sirchaoz's Avatar
Sirchaoz
So im thinking of getting this, do you think it will work?
Im thinking it will match the mesh on the bottem of the bumper
Old Nov 30, 2016 | 09:11 AM
Should work ok, might shoot a PM to STownSaint and see what he used here~ https://www.myg37.com/forums/body-in...le-photos.html
Old Dec 4, 2016 | 09:48 AM
Ape Factory's Avatar
Ape Factory
I did a bunch of research on mesh a long time ago on a planet far, far away and looked at void ratio and airflow. Some of the mesh is small enough that it cuts off 50% of the air trying to enter the grille (vs no mesh). I believe honeycomb was actually the best depending on hole size. Just something to consider if you live in a hot climate or track the car. In my particular application, I was protecting two giant oil coolers on a turbocharged rotary so good airflow was critical.
I don't know how restrictive the stock grill is. And if you use a mesh grille that theoretically cuts airflow by 50%, that may be enough air to cool everything properly.
Pegasus Auto Racing used to have flow rates for various grille materials but it's not up on their site any longer.
Old Jul 16, 2019 | 11:06 PM
cshel777's Avatar
cshel777
I think that would look cool if you epoxy'd the stock emblem in the center. Especially if you have a cai
rk325
Dec 8, 2020 08:14 AM
beng37s
Dec 8, 2019 01:21 PM
cconklin2
Jan 9, 2016 07:21 PM
drewfinity
Sep 24, 2015 11:01 AM
VIVID
Sep 14, 2015 03:31 PM
