Freaking out help :( cars crazy
Guys i own a g37x Coupe 09
Today i had my vossen CV1's installed
FRONT 245/35/ZR20 FALKEN FK453
REAR 285/30/ZR20 FALKEN FK453
BRAND NEW
and my car, when driving starts going left and starts going right but itself.
especially during lane changes
On a straight line its perfect but lets say if i'm changing lanes it abruptly turns without my full input. I have to hold the steering really hard in order to keep car in control.
Please help , the car doesn't shake or anything its just turns by itself.
my car is not lowered everything is stock except for my K&N INTAKES AND TOPSPEED Exhaust .
Air pressure, bad tires ??????? FREAKING OUT !!!!
Offset's are 32 in the front and 42 rear
BRAND NEW
Have you hit any potholes recently? Your alignment may be a bit off and w/ the new wider tires the problems may be magnified. And you mentioned tire pressure, I'd go 35psi.
Anything else performed during your tire install?
I have no idea what my tow numbers are or how to get them
This site I read : When to tell that you need alignment - Auto - monitor.co.ug
Seems to indicate that I have a bad alignment issue
As for the previous question I only had my mags mounted on my new tires and my winters
Removed today . They look beautiful as for the tire pressure
35psi all around ?
You guys think it could be the alignment ?
35psi all around ?
My infiniti dealer is a official vossen dealer you think I should take my car into the dealer or the place I had them installed, because the dealer is really close the other place is about 45min and my cars scaring the crap out of me
The reason I went to that shop is because they gave me the best price on the
New Falkens I mounted on my 2 years old vossens which were driven 2 season in summer only
Thank you for all you quick answers everyone
I'm think alignment , because alignment was bad to begin with
And now my big tires and big mags amplified the bad alignment
Twenty folds. Taking it to infiniti dealer Monday
I doubt it's caster, caster effects lowered cars or cars who have had a
Collision but symptoms do not fit that description or behaves
In a way a vehicle would behave that has a bad caster
My car is also not lowered and has stock g37x suspension
The tires I selected have a differential of 0.33
Also before purchasing everything I made sure I did
All the possible research on this forum
Including verifying my offsets and tires sizes
