Trunk compartment light & Wiring Harness checks
Old May 4, 2015 | 11:48 AM
2008G-Man's Avatar
2008G-Man
My trunk light works but the indicator that the trunk is open stopped working a while ago.
Old May 6, 2015 | 06:48 PM
Dough1397's Avatar
Dough1397
That is quite strange, the 'trunk room lamp switch' tells the BCM whether the trunk is open or closed. The warning that your trunk is open and the trunk light turning on is dependent on the status of this switch.
Here are some pics of the severed wires. Not sure how they were cut, the rubber tube protects them well and they look sliced (pic 2: yellow wire is lightly sliced) rather that stretched. Can't fix it until my crimper arrives on Friday. I am so excited to have a working trunk again, its unbelievable.
Attached Thumbnails Trunk compartment light & Wiring Harness checks-img_20150506_175229.jpg   Trunk compartment light & Wiring Harness checks-img_20150506_175803.jpg
Old Aug 27, 2015 | 07:18 PM
Jbunz's Avatar
Jbunz
I'm juss worried if u fix ur trunk coz mine won't open I check the glove box switch and it on and when I press the button for the trunk it makes 4 beeping sounds but still it doesn't open. Did u figured this out? Need help thanks is it easy to take the wiring cover where the trunk goes up in the side? Need help asap thanks
Old Aug 27, 2015 | 08:42 PM
Dough1397's Avatar
Dough1397
Whoops, I thought I posted an update!
I spliced the two wires together using
heat shrink splices heat shrink splices
and it has worked flawlessly!
It is not hard to take the rubber tube (wiring cover) off, it is a large grommet. Pinch it where it goes into the trunk lid and wiggle it out. Once you have it out, cut the zip tie that holds the rubber to the harness and push the tube down/back. You'll see the severed wire.
You can do it!
Old Aug 27, 2015 | 10:49 PM
Jbunz's Avatar
Jbunz
I spliced the two wires together using heat shrink splices and it has worked flawlessly!
You can do it!
Okay thanks for the help. But is this the problem if ur trunk won't open I check all the things u said like the glove box and the latch n there's power so now I'm stuck. I will check this weekend hopefully its the wiring where the big tube thanks.
Old Aug 29, 2015 | 09:32 PM
Jbunz's Avatar
Jbunz
This work for me thanks for all the help but I had to cut my cover boot coz it was in the middle.
Old Sep 2, 2015 | 08:57 PM
Dough1397's Avatar
Dough1397
Happy to hear you fixed it. Make sure you seal up the rubber tube if you've cut it. Don't want water or ice to get in there.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
Twista
Aug 30, 2015 12:23 PM
STownSaint
Aug 29, 2015 09:04 AM
