Warranty expiring soon, need advice
Old Apr 6, 2013 | 05:31 PM
snydnasty's Avatar
snydnasty
Hey everyone,
My warranty on my 2009 G37S coupe is going to expire soon. I'm hoping you all can give me some advice on things to look out for/check that I may get replaced for free before my warranty expires. I've been searching these forums and interweb for awhile, but haven't really found anything helpful.
I would say that, in general, I don't have great attention to detail, and I don't know what types of things are covered under warranty vs what wouldn't be. Given that, I'm worried I'm going to overlook things and miss the opportunity to get them fixed.
Here's a list of some issues I have noticed that I think should be covered or i could at least get them investigated while under warranty. I've ranked them in order of concern/annoyance to me:
  • Sometimes hear a clicking/ticking noise from engine area when idling when the clutch is pressed in. The noise seems to be at a random cadence and can happen as frequently as 4-5 times in a second or go for several seconds without making the ticking sound
  • Rattling noise in the speaker area of passenger door
  • Hear a little bit of wind when sunroof is shut, I suspect the seal is slightly loose
  • Passenger side fog light does not turn on
  • Breaks squeak sometimes when in reverse
  • Sometimes won't shift into first gear from neutral while stopped. Shifting into second, then back into first fixes the problem
  • Cabin lights flicker when I push on them
  • Chrome finish on rims looks to be peeling off at some spots
  • Driver seat looks very worn and has started to bubble a bit
  • Driver seatbelt does not retract all the time
  • Scratches on interior driver door panel and 2 small dents, probably related to seatbelt not retracting and getting jammed in the door
  • Appears to be some dust/mild scratches on the interior of the headlight glass
However, I don't know what I don't know. How easy is it going to be to get these items addressed? Are there any other things that most of you have taken advantage of? Are there other issues that I should be aware of? Any info or comments are much appreciated.
Thanks,
Dan
Old Apr 8, 2013 | 12:10 AM
snydnasty's Avatar
snydnasty
Lots of views but no responses! I'm not looking for anyone to blow my mind. Any thoughts on my current list of issues? Any general words of wisdom or things to look out for before the warranty expires?
Thanks!
Dan
Old Apr 8, 2013 | 01:49 AM
TwoThree's Avatar
TwoThree
    Let your service writer make note of this and go from there.
    They should replace the moonroof seal
    More than likely needs a bulb, take care of this yourself or pay the dealer to.
    Really depends how good your dealer is. Some will tell you its normal, my buddy had his rotors turned for free, didn't resolve the issue, he complained some more and they replaced all 4 rotors.
    I'm personally not sure what would cause this? Might be the syncros, but I'm not too fond of transmission issues, but I'd let your service write know.
    Could be a bad connection, let the service write know again.
    Doubt anything will come of this, but it doesn't hurt to ask
    I had my seat bottom replaced under warranty, as well as many other due to "seat bubbling"
    If they can duplicate the issue at the dealer, they'll probably replace the mechanism.
As far as the last 2, doubt anything will happen with those either, but it doesn't hurt to ask. Good luck.
Old Apr 8, 2013 | 10:44 AM
rebeltruce's Avatar
rebeltruce
What exactly is "seat bubbling"?
Old Apr 11, 2013 | 08:44 PM
snydnasty's Avatar
snydnasty
Rebel - Not sure how to explain it. Essentially the part of the seat that I sit on is getting worn down and sort of "loose" so it sort of looks like it has a couple big bubbles underneath its surface.
Still looking forward to hearing any other opinions or suggestions!
Old Apr 12, 2013 | 02:18 PM
rebeltruce's Avatar
rebeltruce
Ahhh...mine too.
fuzzed
Aug 21, 2020 09:35 AM
delfinparis
Nov 16, 2015 02:26 PM
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
si_driver
Oct 1, 2015 09:53 AM
