Repair Cost
Old Jan 23, 2013 | 10:33 PM
SCM987's Avatar
SCM987
Repair Cost
How much do you think this would cost to fix? If I'm planning to get a new car in the next year would it even be worth it to fix?
Old Jan 23, 2013 | 11:02 PM
SCM987's Avatar
SCM987
I'm assuming the entire back bummer will have to be replaced.
Old Jan 23, 2013 | 11:11 PM
Modme's Avatar
Modme
Depending on where you go 500-1000.
Old Jan 23, 2013 | 11:35 PM
Weiboy718's Avatar
Weiboy718
That doesn't look that bad! You can try using a blow dryer and heat it up from behind and push it back out.
Old Jan 23, 2013 | 11:39 PM
SCM987's Avatar
SCM987
I will take it to a place to have it looked at the problem with estimates is getting the time off work.
Old Jan 24, 2013 | 12:08 AM
Kevalteam's Avatar
Kevalteam
or get a used bumper and swap it DIY.
Old Jan 24, 2013 | 12:33 AM
john91's Avatar
john91
You could fix this yourself,.. At least straight it out. Use a heat gun to evenly hear surrounding area and than push it from the inside of the bumper, with your hadn.. or something that is nor sharp and wont make bumps or dents
Old Jan 24, 2013 | 02:10 AM
xxg00w0's Avatar
xxg00w0
let ipl bumper 2012 G37 Coupe: G37 Coupe/Convertible Aero - Rear Bumper - One could say there is something to be said of the unique sense of purpose about the aerodynamic lines of the Infiniti G37. The integration of a color coordinated front aero bumper adds a spo
Old Jan 24, 2013 | 11:57 AM
SCM987's Avatar
SCM987
Mine is a 2008. That won't fit mine. It looks different.
Old Jan 24, 2013 | 03:23 PM
Iplcarbon's Avatar
Iplcarbon
SCM not sure where your at but there in Los Angeles Craig list there is a White Coupe 2012 bumper for Sale $125
Get that one paint it and done...DIY in the install yet has the Back up sensors ...
Old Jan 24, 2013 | 03:50 PM
G2Envy's Avatar
G2Envy
If you have or know someone that has a GoPro you could try and suction that area and pull it out?
Old Jan 26, 2013 | 04:44 PM
sydnrusty's Avatar
sydnrusty
i hit a racoon on my way to work with my old car a couple years ago and put a big dent in the front bumper that looks similar to what you have there.
after doing some research i removed the front bumper and used a heat gun to slowly heat the damaged area from the inside. when it was pliable enough i pushed it back out and rinsed with cold water. it worked great. just be careful to heat slowly and not make it super hot. you want to take care not to melt it.
Old Jan 30, 2013 | 12:48 PM
SCM987's Avatar
SCM987
I was quoted a price of $450 to fix or $1100 to replace the bumper. The bumper will need to be repainted if fixed. But he said it will be weak there, so will damage easy plus it won't look 100%.
My rims are also marked up pretty bad. I didn't notice for a few days since I was only worried about the bumper. My insurance company said it isn't worth suing the tow company. Even though they did the damage, I would still probably lose more going to court then I could win,
Old Feb 1, 2013 | 01:54 AM
TwoThree's Avatar
TwoThree
Where are you located? I have a rear bumper in Blue Slate.
37
Oct 17, 2020 11:12 AM
Upscale Speed
Dec 26, 2015 08:45 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
parkern
Oct 1, 2015 10:15 PM
dedmanchan
Sep 24, 2015 11:25 PM
