Good start to Memorial Day weekend...
Old May 26, 2012 | 02:02 PM
OB G's Avatar
OB G
So I was washing my car on this beautiful morning. Went to wash my wheels and what do I see? It's cracked on one of the spokes!! Mind you I've had these powdercoated. Does that take away some of the integrity of the wheel? Is the spoke actually cracked or is it just the powder coat? Any input would be appreciated. I would take it to a wheel shop to have them diagnose it but everyone's closed for the long weekend...
Old May 26, 2012 | 02:06 PM
JohnnysG's Avatar
JohnnysG
Looks cracked ... I've heard powder-coating does hurt the integrity of the wheel, but I'm not too sure how accurate that statement actually is...
Old May 26, 2012 | 02:56 PM
YewWanSum's Avatar
YewWanSum
Yes depending on the method the place used to remove your factory finish then yes it can damage the rims integrity. If they put the wheels in an oven or sandblasted them for example. There is one method that doesnt reduce the integrity and it's a process of shooting tiny metal pellets at the factory finish to easily remove the paint...call your powder coater and see how they removed the factory paint if they put them in a furnace or sandblasted then it only a matter of time before the others crack too.
Old May 26, 2012 | 03:39 PM
soundmike's Avatar
soundmike
The reason folks say PC compromises the metallurgy of the wheel is because of the heat applied to melt and harden the powder -- the temperature and duration of the heat-curing is typically within the same 375-400 range (which coincides with the aging process used on the type of aluminum used.)
Long story, it overages and fatigues the metal.
Reference: Metal and Metallurgy engineering - Aluminum wheel failure after powder coating?
Old May 26, 2012 | 05:28 PM
dtran2714's Avatar
dtran2714
Sorry to say but that looks cracked based upon pictures posted.
Old May 26, 2012 | 09:11 PM
AnJing408's Avatar
AnJing408
another reason why i stick with OEM factory wheels. Not a fan of aftermarket wheels, i've only seen a few aftermarket wheels that actually looks decent.
Old May 26, 2012 | 09:25 PM
thedeadking's Avatar
thedeadking
This is why you should have your wheels painted instead of powder coated due to the negative effects of the baking process on forged wheels.
Old May 26, 2012 | 09:28 PM
soundmike's Avatar
soundmike
These are Advans, they're generally highly regarded.
Old May 26, 2012 | 10:54 PM
TwoThree's Avatar
TwoThree
As a few others have stated, mainly Soundmike, the heating process is what makes the aluminum more brittle, resulting in your cracked wheel. Hopefully all the others will remain ok. Sucks man.
Old May 26, 2012 | 11:03 PM
P Casey's Avatar
P Casey
When were they pc'd??? If they person pc'ing your wheels was a complete idiot and made the temp too hot and kept it hot for too long then it can affect the wheel, but if they did it right it should be fine.
Old May 26, 2012 | 11:04 PM
P Casey's Avatar
P Casey
But yea, take it to someone on Tuesday and see what the problem is.
Old May 27, 2012 | 01:36 AM
NeverBoneStock's Avatar
NeverBoneStock
Cracked !!!!
Old May 27, 2012 | 08:00 PM
OB G's Avatar
OB G
Thanks for the responses guys. It looks like it's been unanimously decided by everyone that it's cracked. Still hoping it's not lol. Crossing my fingers and praying to the car gods that it's just the PC that's cracked and that I can just get it redone.
If it is a crack in the spoke do you guys recommend getting it repaired?
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
filipinowise
Intake and Exhaust
Sep 24, 2015 04:18 PM
Digilog
Sep 18, 2015 01:53 PM
joeposter
Sep 8, 2015 04:36 PM
