Question about splash guard
Old Oct 28, 2011 | 07:24 PM
vmfldis's Avatar
vmfldis
The part where it's circled in red, is that the splash guard?
I wasn't sure what this part was called.
Old Oct 28, 2011 | 07:28 PM
Yes, that's the rear splash guard.
Old Oct 28, 2011 | 07:29 PM
da mayor's Avatar
da mayor
its an accessory
Old Oct 28, 2011 | 07:36 PM
vmfldis's Avatar
vmfldis
does anybody knows if if you get this from factory is it taped? or just installed by screws?
Old Oct 28, 2011 | 07:38 PM
da mayor's Avatar
da mayor
some cars come in as a factory option but you can order it as an accessory from any Infiniti dealership. it is screwed and double sided tape
Old Oct 28, 2011 | 07:41 PM
vmfldis's Avatar
vmfldis
The reason I'm asking this is because I was rear ended few days ago and body shop replaced the bumper but they were unable to reinstall the splash guard. They tried to reinstall(reusing the old splash guard) it by using double sided tape but tip of the splash guard keeps falling off.
Old Oct 28, 2011 | 07:42 PM
vmfldis's Avatar
vmfldis
They said it was mayb bented along with the bumper when the car was impacted so they asked me to buy new set.
Old Oct 28, 2011 | 09:14 PM
myk1013's Avatar
myk1013
how does the splashguard look? are they bent (as in creased?)
They are made polyurethane (I think) and very flexible. If they weren't badly creased or bent then some double sided tape and adhesive shouldnt be a problem.
New set for the rear will cost around $75.
Old Oct 28, 2011 | 10:47 PM
kkokko's Avatar
kkokko
Does front guard have double side tape?
Old Oct 29, 2011 | 10:17 PM
nbast's Avatar
nbast
Different question about splash guards...
I just bought a 2009x without splash guards. The dealership wants $92 per pair plus $100 to install them. How much could I get them for online, and how hard are they to installed on my own?
Old Oct 30, 2011 | 12:34 PM
myk1013's Avatar
myk1013
$92 is ok, you could probably get them a little cheaper somewhere else. (eBay, other dealers etc...)
But $100 to install them is OMFGWWTT!!!
It takes 15 mins TOPS to install. Took me that long to install my rear splash guards.
Old Oct 30, 2011 | 12:38 PM
TVPostSound's Avatar
TVPostSound
Might stick with dealer. Online they are ~$80 plus shipping.
Installing them is a piece of cake.
As long as you can remove a wheel, and make 1 1/8" hole with a drill!!
Old Oct 31, 2011 | 06:58 PM
1NEETO's Avatar
1NEETO
Only now I realized my car has the splash guards.
Old Oct 31, 2011 | 07:06 PM
SleepyMonkey's Avatar
SleepyMonkey
...ditto!
Old Oct 31, 2011 | 07:11 PM
ReddieG37's Avatar
ReddieG37
My guess is the body shop started removing the splash guards from the tip. Since there is double sided take all long the edges, they probably had to use some force to pull it off. You can try finding stronger double sided tape.
peterso2
Mar 25, 2019 11:28 AM
JG_G37
Sep 19, 2015 09:07 PM
nbast
Sep 14, 2015 12:39 PM
gdaelemans
Sep 13, 2015 09:36 PM
User 122320
Sep 4, 2015 05:25 PM
