Creeking Fixed
Old May 31, 2011 | 01:12 PM
Trincap's Avatar
Trincap
Creeking Fixed
Just fixed the horrible creeking sound coming from the suspension. It basically happened whenever the car started to go down. So on the downslope of a speed bump or hill or frankly anything.
Anyways, I was pretty sure it was the Hotchkiss sway bar and I finally got around to jacking it up and checking it out. Yep, that was it. Just take off the Zeta thing you can use to shoot grease in via a grease gun. I don't have one so I got a free injector from the drug store. Once you take it off there's a hole. Just inject some silicon grease and. . . you're done. Creaking is totally gone.
Old May 31, 2011 | 01:49 PM
breftayka's Avatar
breftayka
Haha. Sorry if it's a silly question, but can you clarify the zeta thing? I have stock sways, but randomly get a creaking noise as you described.
Old May 31, 2011 | 02:34 PM
I think you mean the grease zerk.
Old May 31, 2011 | 02:39 PM
breftayka's Avatar
breftayka
Ahhh I can understand that language lol. I actually have a grease gun.
Old May 31, 2011 | 07:27 PM
Trincap's Avatar
Trincap
Sorry, yeah the zerk thing. At first I was just putting it in manually which is pretty annoying. Then it came to mind to use a syringe. That worked great. I'm actually pretty psyched. All my creaking has gone away.
Old May 31, 2011 | 08:19 PM
mystakin's Avatar
mystakin
i have that creek sound with my stock suspension. im wondering if it might be this.. dealership told me it was my painted calipers since some overspray got on the brake pad mounting spots which was in turn causing the creeking..
Old May 31, 2011 | 08:29 PM
1NEETO's Avatar
1NEETO
Dealership will tell you just about anything to get out of a warranty repair. Overspray on the brake caliper making cradling noise makes no sense to me.
Old May 31, 2011 | 10:02 PM
mystakin's Avatar
mystakin
right?? i was like uh that doesnt make any sense but ok..
im hoping this is the issue lol
Old May 31, 2011 | 10:08 PM
Unique Bliss's Avatar
Unique Bliss
I was told the exact same thing... That's too funny!
Old Jun 1, 2011 | 09:37 PM
Trincap's Avatar
Trincap
I think the factory sway bar does have a bracket (don't they all?). Look up the Hotchkiss sway bar for G37 and there's good instructions on how to get to the sway bar. It's super easy. Just take off the cover. Then put some silicon synthetic grease into the bracket and you are good to go. I gotta tell you, this is the happiest I've been with my car in like 6 months. Rides nice and quiet again. . . uh other then that stupid poorly built convertible roof of theirs; but that's another story.
Old Jun 2, 2011 | 06:53 AM
mystakin's Avatar
mystakin
I get the weird creaking sound sometimes when I'm idling too ill try to get it on tape and upload it to see what you guys think. Gonna try this sometime later this week just to see if it works!
Old Jun 2, 2011 | 04:23 PM
Xenolith666's Avatar
Xenolith666
I've got the same thing, mostly on the driver side rear. It'll creak when I get out of the car, or sometimes sit in it. And hell, I only weigh 150lbs. So it's not a 'fat ***' issue! Any chance you can post some pics? My sways are currently stock still. Perhaps write up a DIY for us slackers!
Old Jun 2, 2011 | 08:02 PM
Trincap's Avatar
Trincap
It's quite easy. Here's the instructions:
http://www.hotchkis.net/_uploaded_files/22441.pdf
Now do NOT do #3 (disconnect end links), just do #4 (remove the bushing) or don't even bother disconnecting them and just use a syringe to goop some Silicon Grease in there. I used the Mobil Synthetic one. It's blood red. I would assume it's easier if you take the bushing off but the Hotchkiss one had a little nipple thing on the bottom (the zerk) that you could just twist off and then apply the grease through the hole. After that, just put the bushing back on and put the cover back on. Voila, creeks are all gone. I'm very happy with the results. Shouldn't take more then 30 minutes to do.
Old Jun 2, 2011 | 10:21 PM
mystakin's Avatar
mystakin
going to do this tomorrow! i sprayed some wd-40 on it and the sound went away. did it as just a quick fix. hopefully this works for me too!
Victory
17
Oct 27, 2022 03:45 PM
delfinparis
Nov 16, 2015 02:26 PM
parkern
Oct 1, 2015 10:15 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
Chris_M
Sep 25, 2015 08:38 PM
