Car won't let me put gas in!
Old Nov 27, 2010 | 04:12 PM
himz's Avatar
himz
Exclamation Car won't let me put gas in!
Last night I went to get gas as the car showed 1/8 remaining. It took in 4.5 gallons and then the nozzle clicked off (like it does when the tank is full). I tried again and it kept clicking off and won't let me put gas in. Then I tried a different pump, and got the same problem. It took like 0.1 gallons and clicked off, and won't take in anymore.
Right now my car shows a little under half a tank of gas. I've setup an appointment at the dealership for Monday, but wondering if anyone here has ideas about what the hell's going on!
Old Nov 27, 2010 | 04:21 PM
Gunit37's Avatar
Gunit37
I had the same problem few times..
Old Nov 27, 2010 | 04:38 PM
emyrl's Avatar
emyrl
I've had that happen a few times too. Pretty annoying, I'm not sure what the whole problem is so I'm interested as to what you find out.
Old Nov 27, 2010 | 04:43 PM
xixonmn's Avatar
xixonmn
Turn the nozzle to the left at about 90 degree and put it in that way.
Old Nov 27, 2010 | 05:26 PM
thebaran06's Avatar
thebaran06
Don't put it in so far, pull it out a little bit and try again. If the pump pumps really fast it gets blocked up quickly and thinks the tank is full. If you pull it out a little it allows a more sure flow. If that doesnt work try a new gas station
Old Nov 27, 2010 | 06:17 PM
NonAme's Avatar
NonAme
Car trying to tell you it doesn't want that 87 octane crap you feeding it...lol jk
Old Nov 27, 2010 | 06:21 PM
briann510's Avatar
briann510
Its the POS gas nozzle causing it not your car. Ive had it happen once.
Old Nov 27, 2010 | 06:43 PM
amf25's Avatar
amf25
me too day before yesterday, it was at a brand new ARCO station. Was able to fill it up by barely squeezing the nozzle and trickling it in to restart, and then sped up slowly. Got it full though. Whoever find the fix, please post up.
Old Nov 27, 2010 | 07:24 PM
mike904's Avatar
mike904
My car does it at times also. When it happens, I will slow the flow of gas for a couple of gallons and then the gas will flow normally.
Old Nov 27, 2010 | 09:34 PM
alyx's Avatar
alyx
I've had the same thing happen at a specific pump. If I avoid the pump, everything works fine. So I'm pretty sure it's a pump issue and not a car issue.
Old Nov 27, 2010 | 10:14 PM
Wezbian's Avatar
Wezbian
This works. if you're looking at the gas cap as a clock then you usually have the nozzle at 6 o'clock, turn the handle to 9 o'clock and it will work.
Old Nov 27, 2010 | 10:30 PM
beancounter10's Avatar
beancounter10
I've had this happen to me 3 times at 3 different pumps. I'll try the suggestions here next time. Thanks
Old Nov 27, 2010 | 11:03 PM
123u's Avatar
123u
actually did happened to me a few time with my other car. simply avoid those (cheap)gas station. I only used Shell/Exxon 93 all the way. hope this will help.
Old Nov 28, 2010 | 12:05 AM
beancounter10
The times its happened to me was at Shell/BP/Exxon
Old Nov 28, 2010 | 12:14 AM
spect2k's Avatar
spect2k
I am having a similar issue. The car is filling up but only to 3/4 of a tank. I've tried different pumps and different stations. I too will be taking it in to the dealer. Let us know what your resolution is.
This is my second nissan/Infiniti and both have had gas filling difficulties. Weird.
