want the doors to lock when I walk away...
Old Sep 18, 2010 | 12:05 PM
Frankyg37s's Avatar
Frankyg37s
Originally Posted by Ken
LOL I always end up pressing the panic key on accident. I usually have my keys in my pocket and bump it up against something when im working on the car--scares the crap out of me
hahaha i must of done this 4 times yesterday
Old Sep 18, 2010 | 02:15 PM
sunten1's Avatar
sunten1
Originally Posted by rocky
There was a thread at one time that listed a bunch of different customizable options you could change. This covered things such as how long your headlights would stay on after you turned off the car. I can't find the thread however but I will keep looking.
-edit- I found this one.
Keyfob Programming Options
Here is what it lists:
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
How do you set this up?
Old Sep 18, 2010 | 10:35 PM
rocky's Avatar
rocky
Supposedly a dealer can configure this stuff. But I was hoping someone on the boards could confirm that...
Old Sep 19, 2010 | 01:35 AM
surfjax87's Avatar
surfjax87
Alright,
Hazard and Horn Reminder Mode (pg 3-18 in 2009 owner's manual)
Hold lock and unlock on key fob for more than 2 seconds to switch between modes 1 and 2. Going from 1 to 2 flashes the hazards 3 times to confirm, going from 2 to 1 the horn beeps once and hazards flash once to confirm change.
Selective Door Lock/Unlock, Auto Light Sensitivity, Headlamp Illumination Delay, Auto Interior Illumination/Dome Lamp Timer, Disable SmartKey(pg 4-7)
Go to settings on lcd screen, click comfort and convenience to see these options.
Can't find any info on how to disable anti-lock out feature. Default setting for sunroof/window power is 45 seconds, no mention of how to change it.
On my car, the doors auto lock after 5 minutes if the keys are outside of the car and door sensor range. I don't trust it enough to not hit the lock button though.
So...
I think you might have to visit the local dealer to change Anti-lock Out, Head Lamp Battery Saver, Retained Power, Remote Auto Locking Function Mode.
Old Sep 19, 2010 | 05:09 PM
sunten1's Avatar
sunten1
I swear a few months ago I was washing my car, and I remember I had it unlocked. After like 10 minutes or so I went to clean inside the doors and I noticed it was locked... I went and unlocked it and cleaned the door. Like 1 minute later I noticed the lights flash and the doors were locked. I would love to have this feature activated again, because I tried it again after that a few times and noticed it didn't happen again...
Old Sep 19, 2010 | 08:56 PM
rocky's Avatar
rocky
Sure would be nice if someone would take their 2009 G37x to a dealer real quick and request Mode 3 of the Remote Auto Locking feature and let us know what happens!
Old Sep 20, 2010 | 10:10 AM
carz's Avatar
carz
Im gunna take my car in a few weeks for its first oil change, ill make sure i have them try this
Old Sep 20, 2010 | 03:19 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
I'm at my dealer now. The tech is looking to find the info on the remote autolock. Where was the source for the info? Like which model year started to have this? And is it for all models. I know surjax has an 09 sedan
Old Sep 24, 2010 | 12:17 AM
cereal2k's Avatar
cereal2k
So no luck at the dealer this does not exist for them. Where ever it's quoted from it does not work with the G as they can't program the key for Remote Auto Locking.
Old Sep 24, 2010 | 12:21 AM
cereal2k's Avatar
cereal2k
So there is an option, it's in that quoted list Rocky posted that is default for all the Gs. If you lock the car and open it with the key fob within a certain time the car will auto lock in the specified default time period. They assume after you first locked the car you accidentally unlocked it. So it "auto locks" the car after that delay. This can't be disabled.
This is not the same as parking and leaving the car and having it auto lock by itself.
timc00k
Feb 15, 2017 09:15 AM
*ICE*
Oct 5, 2015 03:05 PM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
Murkr
Sep 28, 2015 10:45 AM
