I cant seem to turn off VDC
Old Oct 10, 2008 | 11:40 AM
DetroitG37Joe's Avatar
DetroitG37Joe
Originally Posted by Loi
Do you save gas by turning VDC off?? just wondering.
Ive wondered that too - any answers to that?
Old Oct 10, 2008 | 07:46 PM
jasonviper's Avatar
jasonviper
I dont see why you would. in fact it may save you gas because it cuts power when you get a really heavy foot.
Old Oct 10, 2008 | 10:52 PM
pass1over's Avatar
pass1over
this was talked about to exhaustion on the rx8 boards (the car has basically the same feature to turn off) You dont save gas
Old Oct 10, 2008 | 10:56 PM
GiGGaplease's Avatar
GiGGaplease
Originally Posted by shumby
^^^ I get cheep tires and the smoke them is fun. ;-)
400 for 2 rears is not cheap.
want to buy me 2 rears? ship it to 70454
Old Oct 17, 2008 | 07:42 PM
SaADooNEsS's Avatar
SaADooNEsS
vdc and traction are turmed OFF when u press the button! what u r feeling is the limited brake differential ! this system controls ur tires to spin TOGETHER only! the system does that by applying brakes! it will not interfere with ur drifts if u get the drift right
Old Oct 17, 2008 | 08:09 PM
G37RacerX's Avatar
G37RacerX
wrong...
Old Oct 18, 2008 | 06:00 AM
SaADooNEsS's Avatar
SaADooNEsS
Originally Posted by G37RacerX
wrong...
be my guest...correct me and the infiniti manual. its clearly ststed that the AT g37s have a brake limited slip differential
Old Oct 18, 2008 | 06:37 AM
NismoVQ37's Avatar
NismoVQ37
Thats why i cant do a damn burnout at the wet box!
Old Oct 18, 2008 | 08:03 AM
04STi208G37's Avatar
04STi208G37
wrong...
From the Manual:
"The VDC system uses an Active Brake Limited
Slip (ABLS) function to improve vehicle traction.
The ABLS system works when one of the driving
wheels is spinning on a slippery surface. The
ABLS system brakes the spinning wheel, which
distributes the driving power to the other drive
wheel. If the vehicle is operated with the VDC
OFF switch pushed and the VDC system turned
off, all VDC systems will be turned off. The ABLS
system and ABS will still operate with the VDC
system off. If the ABLS system is activated, the
SLIP indicator will blink and you may hear a
clunk noise and/or feel a pulsation in the brake
pedal. This is normal and is not an indication of
a malfunction."
That is only part of the manual. It's a great tool and is available in pdf form. It also says VDC cuts power. The sport model has a viscous LSD also. In my experience with VDC off in autoX, there is no loss of power and the ABLS does not seem to hinder the LSD. Of course, in autox we don't like to drift as it wastes TIME and tire.
Old Oct 18, 2008 | 10:32 AM
jasonviper's Avatar
jasonviper
I knew it wasnt just my imagination! I have the sport package also .
Old Oct 27, 2008 | 03:36 AM
ifinity's Avatar
ifinity
BRAKE CONTROL SYSTEM p#10
• Vehicle Dynamics Control system detects driver′s steering operation amount and brake pedal travel from
steering angle sensor and pressure sensor. Using information from yaw rate/side G sensor and wheel sensor,
VDC judges driving condition (conditions of under steer and over steer) to improve vehicle driving stability
by controlling brake application to 4 wheels and engine output.
• During VDC operation, it informs driver of system operation by flashing SLIP indicator lamp.
Owner's Manual
2-39: The vehicle should be driven with the Vehicle Dynamic Control (VDC) system on for most driving conditions.
If the vehicle is stuck in mud or snow, the VDC system reduces the engine output to reduce wheel spin. The engine speed will be reduced even if the accelerator is depressed to the floor.
If maximum engine power is needed to free a stuck vehicle, turn the VDC system off.
5-49: When accelerating or driving on slippery surfaces, the tires may spin or slide. With the Vehicle Dynamic Control (VDC) system, sensors detect these movements and control the braking and engine output to help improve vehicle stability.
c When the VDC system is operating, the ªSLIPº indicator in the instrument panel blinks.
c If the ªSLIPº indicator blinks, the road conditions are slippery...
-If a malfunction occurs in the system, the ªSLIPº and ªVDC OFFº indicator lights illuminate in the instrument panel. As long as these indicators are illuminated, the VDC system function is canceled.
[...see post by 04STi208G37 above...]
While the VDC system is operating, you may feel a pulsation in the brake pedal and hear a noise or feel a vibration from under the hood. This is
normal and indicates that the VDC system is working properly.
The VDC system computer has a built-in diagnostic feature that tests the system each time you start the engine and move the vehicle at a low speed forward or backward. When the self-test occurs, you may hear a ªclunkº noise and/or feel a pulsation in the brake pedal. This is normal and is not an indication of a malfunction.!!
--I have not noticed this...my wife says that I am an insensitive Lout.
timc00k
Feb 15, 2017 09:15 AM
Rybitron
Nov 18, 2015 03:11 PM
parkern
Oct 1, 2015 10:15 PM
Landshark
Sep 29, 2015 11:20 PM
MrRiv
Sep 29, 2015 04:59 PM
