I need some advice on what to do with my new car.
Old Apr 29, 2008 | 07:26 PM
patmsb1's Avatar
patmsb1
Hi. I have a Black G37 w/MT6, sport package and 8500 miles on it. I have been having a nasty metal rattling sound coming from my engine and the muffler issue as well. I have taken my car to the dealer at least 2 times for the same problems. I dropped off my car yesterday for the 2nd. oil change and some warranty work on the issues listed above. When I dropped off the car the engine sounds where more than apparent and to me louder than usual. The service writer left my car on so the tech. could here the problem because it wouldn't do it all the time. I was called today from the service writer telling me that Infiniti told them that it could be bad gas or not using premium gas. If this was the case my engine would be knocking, right? I use Chevron or Shell and it's the premium 91 octane so that can't be the problem. The service writer also said that Infiniti is working on the problem even though there guessing on what the problem is. I also told the service writer that the engine used a whole quart of oil when I brought it in. The problem seems to be a lubrication issue vs a gasoline problem. I'm no mechanic but metal hitting metal doesn't seem right when it's coming from the
engine. The service writer said we can't fix it and to come pickup the car and return the rental. What's my other options for my problems? Lemon Law?
Old Apr 29, 2008 | 07:33 PM
patmsb1's Avatar
patmsb1
It's not a chucka, chucka sound like I just found under engine posts. I'll post a sample of the noise when I get my car back.
Old Apr 29, 2008 | 08:26 PM
ppc's Avatar
ppc
A quart of oil in how many miles?
If the dealer was able to observe the symptoms and state it is or isn't a problem. The same with oil comsuption. If they say its not a problem then making them put in writing what is an acceptable amount of oil usage or acceptable noise. If they admit that something is wrong and they are not just waiting for replacement parts, force them to keep the car until they can properly diagnose and fix the problem. don't stop at the service writer go to the dept manager. If that fails start to wearout your salesman right in front of the other customers. That will get them a bit more motivated to solve the problem. Last resort call Infiniti customer service.
Old Apr 29, 2008 | 08:40 PM
ohseedee's Avatar
ohseedee
If they cant fix the issue then it sounds to me like lemon law might be in play. Call Infiniti customer service.
Old Apr 29, 2008 | 08:46 PM
go4gr8's Avatar
go4gr8
Could it be a timing problem? Maybe reset the ECU?
Could also be a loose belt or pulley?
Old Apr 29, 2008 | 09:17 PM
Genome's Avatar
Genome
Find out your state's lemon law guidelines...
because while every state may differ somewhat, you might be better off accepting the vehicle back with the admission that the condition still exists - oftentimes, three trips for the same issue(if unrepaired or not) would qualify for lemon law treatment, as might car out of commission for some cumulative # of days - say 20 or so. But I'm no lawyer, so check the internet(google "how to qualify for lemon law" and you can usually get a free evaluation/guidance from an attorney). I've found Infiniti Consumer Affairs to be pretty weak (i.e. more interested in putting you off than actually addressing your concerns); their answer is usually to direct you back to the dealer. Sorry about your troubles and good luck!
Last edited by Genome; Apr 29, 2008 at 09:34 PM. Reason: correct errors & add info
Old Apr 29, 2008 | 09:33 PM
patmsb1's Avatar
patmsb1
The Tech. was told by Infiniti that replacing parts and trying to troubleshoot the problem was not encourage and may make the problem worse. At this point the service writer's hand was tied and none of the problems resolved making this almost a complete waste of my time. I also told them that other user's on this board with the same car had the rattle and reported that the muffler was the problem and other dealerships have also confirmed this. Getting all these visits documented is a good idea so I can prove that I have tried to address these issues. Thank you!
Old Apr 29, 2008 | 10:23 PM
G37SUM!'s Avatar
G37SUM!
PatmSb1... we are on the same boat. My car has been to the dealership 3 times and currently still there for the SURGE issue, rough idle, SES always coming on, one cylinder misfiring... Worst of it all they gave me a 04 G35 loaner and it was pratically about to overheat. My car is only 3 months old, babied and only has 2k miles. Anyone knows the fee if I terminate my lease right now ,I have 21 months left!
Old Apr 29, 2008 | 10:35 PM
ohseedee's Avatar
ohseedee
This 100% sounds like a lemon law case. Infiniti is saying anything they do will make the problem worse, which means there is a problem and they cant fix it, so its a lemon.
I've been really disappointed with Infiniti and their service. I've got a problem with my AC...and I've been trying to get Infiniti to fix it but they said there is nothing they can do.
https://www.myg37.com/forums/body-interior-exterior-lighting/178670-a-c-is-very-loud-whats-the-problem.html
Old Apr 29, 2008 | 11:27 PM
patmsb1's Avatar
patmsb1
It's to bad because I really like there cars but hate there service. I had a bad feeling after the first time I tried to get a problem resolved. Don't goto Infiniti of Oxnard, California because there service and attitude is very poor. Thank you!
Old Apr 30, 2008 | 07:30 AM
Potty_Pants's Avatar
Potty_Pants
could be parts of the cat rattling around in the exhaust system.
just take it to another dealer.
good luck
ppp
Old Apr 30, 2008 | 12:51 PM
go4gr8's Avatar
go4gr8
So why not go to another dealership?
Old Apr 30, 2008 | 01:52 PM
BiskitG37's Avatar
BiskitG37
I bought my car at one dealership, get service done at a different one. Another dealership may be the best option - see what they can find out.
Old Apr 30, 2008 | 02:09 PM
G37SUM!'s Avatar
G37SUM!
Can you go to other dealerships to get service if you didnt purchase and or lease the car there?
Old Apr 30, 2008 | 04:27 PM
Achilles's Avatar
Achilles
As long as it's another Infiniti dealership, absolutely. This is how you can get service anywhere in the country that has an Infiniti dealership.
