2008 g37 specs
Old Mar 31, 2007 | 01:06 PM
6969g35's Avatar
6969g35
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
2008 g37 specs
2008 Infiniti G37 Coupe
Base Price $35,000 (est)
Vehicle Layout Front engine, RWD, 4-pass, 2-door
Engine 3.7L/330-hp/270-lb-ft DOHC 24-valve V-6
Transmission 6-speed manual, 5-speed automatic
Curb Weight 3600 lb (MT est)
Wheelbase 108.3 in
Length x Width x Height 182.1 x 73.0 x 54.0 in
0-60 MPH 5.2 sec (MT est) auto 5.5
EPA City/HWY Econ 20/27 mpg (MT est)
On Sale In U.S. August 2007
Old Mar 31, 2007 | 01:31 PM
CrazyRuskie's Avatar
CrazyRuskie
Crazy Russian Super Mod
Honestly, how can they possibly think its going to be only as fast as the 07 Sedan? 07 Sedan has 306hp, this has 330, and the weight difference is negligible .
Old Mar 31, 2007 | 01:43 PM
RBull's Avatar
RBull
It will probably be slightly faster but I wouldn't expect much. The weight is about 3-4% more than the sedan. Torque has no peak gain, broader curve and peak hp up about 8%. Gearing has changed which may have the largest bearing on any change in acceleration.
Old Apr 2, 2007 | 12:30 AM
trebien's Avatar
trebien
Agreed... I doubt any official testing gets to 60 in under 5.
Old Apr 2, 2007 | 02:36 AM
CrazyRuskie
I think the mags will be running 5.0 and people will be hitting 4.8 - 4.9 but thats me
Old Apr 2, 2007 | 06:07 AM
FAST1's Avatar
FAST1
Actually it's generally the other way around. The guys who do the testing for the magazines are quite good since they drive cars hard all of the time. Moreover, they will run multiple tests at various RPM launches until they get the absolute fastest run from that car. Car abuse means nothing to them since they don't own the car. Finally, most magazines will adjust for conditions. So if the temperature is really hot or they test at a high elevation, some time will be subtracted from their test drive.
Bottom line is that for most magazines, the time posted will be really tough to exceed unless you use some measuring device inside your car that is no where near as accurate as the guys use at the magazines. A much better indication of the performance that you can expect to get from your car comes from the manufacturers.
sLADe781
32
Nov 28, 2015 03:23 AM
Slateg37
Sep 16, 2015 05:52 PM
GW330
Aug 12, 2015 12:19 AM
reigle9
Aug 6, 2015 02:45 PM
