Wheel Offsets on Sport
Old Aug 3, 2023 | 01:37 PM
blackandwhite's Avatar
blackandwhite
Okay, so the stock wheel step for the Sport is :
Front: 19 X 8.5 , 43mm offset
Rear: 19 X 9.0 , 45mm offset
I am considering going with a set of 4 that is 19 X 8.5, 40mm offset, all around....
Just wondering if that 3-5mm difference is gonna make it touch the calipers, or if removing the staggering is gonna cause me some unforeseen suspension or tire wear issues.
Any feedback is appreciated
Old Aug 3, 2023 | 02:49 PM
projectpanda13's Avatar
projectpanda13
Caliper clearance will solely be based on the specific wheel model and sizing. The general 19x8.5 +40 isn't enough information to know for clearance since two wheels can have the same specs but different clearances.
Example: Enkei RPF1 18x9.5 +38 wont' clear and needs a spacer, but Gramlight 57CR 18x9.5 +38 will clear. Both have the same width and offset but the spoke profile are designed different.
What wheel model are you considering?
Old Aug 3, 2023 | 03:11 PM
blackandwhite
Konig Myth https://hardmotion.com/konig-myth-19...8aArWIEALw_wcB
Old Aug 3, 2023 | 03:23 PM
projectpanda13
Originally Posted by blackandwhite
gotcha, on Konig's website, they list that A profiles are more clearance for big brakes. Their website is a little confusing for me to know which sizes have the A part number, but you can always call them also.
https://konigwheels.com/wheels/main-line-wheels/myth/
for tires, since the offset is on the conservative side, I'd actually suggest going with a 255/45R18 tire. This will provide a meaty look, is a 27" diameter tire so it will fill the gaps all around better and is still around what oem diameter is, meaning your speedo isn't affected.
A 255/45R18 is within the ETRTO/TRA approved rim sizing.
Old Aug 3, 2023 | 03:50 PM
blackandwhite
So you are suggesting an 18 inch wheel as opposed to an 19 inch wheel?
Old Aug 3, 2023 | 03:54 PM
projectpanda13
i am so sorry, my mind was thinking of another thread. please disregard that comment about the tires. 18' vs 19' is just preferences so if you like 19", stick with 19"
but on the topic of tires, you can do a 255/40R19 on that 19x8.5 +40
Old Aug 3, 2023 | 11:33 PM
mummy2's Avatar
mummy2
Ask Z1 since they sell it. https://www.z1motorsports.com/konig/...931.html?m=G37
FancyZ
Jan 23, 2022 11:22 AM
2009G37XSedan
Feb 26, 2021 07:20 PM
mjnoles1
Jan 3, 2016 01:43 PM
1slowvq37
Jan 20, 2011 05:36 PM
kkokko
Dec 17, 2010 11:28 AM
