vert top stops mid-open SOMETIMES
Old Apr 20, 2023 | 08:43 AM
JRizzie's Avatar
JRizzie
only had the vert for about a 1000 miles, top has been working without issues. 2-3 months ago the battery died and after having it replaced things were acting up (window wasn't going down then back up after opening/closing door but window relearn fixed that), and i also had the top get stuck once putting it down. it seemed like the flipper arms were catching, but turning the car off and back let me move the arms a few inches by pressing the open button each time. after 6-8 times the arms fully opened up and the rest of the opening procedure finished without issue. closing it again had no issues, then i opened again with no issues.
fast forward to today and the same issue happened with the flippers catching. Same process above worked again, but this time i took it to the dealer thinking i would need a top re-learn done. i show up with the top down, they take it back, and 10 minutes later they bring it back out saying the top is working without issue. i get it, test it, no problems, no charge.
anyone know what's going on? is there a mechanical piece getting ready to fail - flipper gear or something else? - or do i need a top re-learn done?
Thanks
Old Apr 20, 2023 | 07:50 PM
kiseliok's Avatar
kiseliok
G37 Community Team
It's possible that your flapper gear(s) is(are) failing.
Check out this thread. Guy might be able to tell you for sure if you catch the issue on the video.
https://www.myg37.com/forums/g37-con...s-replace.html
rdog
G37 Convertible
13
Nov 3, 2022 08:57 AM
3BOSH
G37 Convertible
Nov 3, 2020 01:38 PM
Kenneth Rangel
General Tech Questions
Dec 11, 2019 02:53 PM
Lusain
G37 Convertible
Jul 6, 2017 07:52 AM
Scott Clark
G37 Convertible
Aug 8, 2016 03:55 PM
