Parcel shelf repair
Old Jun 8, 2022 | 02:01 PM
n559br's Avatar
n559br
Parcel shelf repair
After pulling the center roof panel to repaint it the parcel shelf stopped operating. Would not move vertically. I was able to get the panel removed and the frame out of the car. This was obviously not the original as my car is a 2011 and the frame was built in 2013. I started by looking at the harness and found the 2 heavy wires with the insulation rubbed off. I was able to order new connector pins and shells from Mouser and will splice new wire onto these and replace it. However, I'm trying to figure out what they were rubbing against to break through the insulation in such a manner.
I also found out that the lift motor is the same one used on the Volkswagen phaeton motor slide. I'm still looking for a replacement number for the tilt motor.
Old Jun 8, 2022 | 02:49 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by n559br
...I also found out that the lift motor is the same one used on the Volkswagen phaeton motor slide. I'm still looking for a replacement number for the tilt motor.
Little tidbit/ fun fact, the top was designed in Germany by Karmann... I am sure that mechanism is in practically all BMW/ Audi/ models...
re: wire insulation... it almost looks to me that those wires were being twisted, perhaps as the shelf raises/ lowers it causes the harness to flex?
You are very lucky in that you are able to diagnose, troubleshoot, and repair these roof issues. And thank you for documenting as these issues arise.
GeeMan37x
Jul 7, 2024 02:38 PM
miguel29
Jan 26, 2022 11:31 AM
Ceo4eva
General Tech Questions
18
Jan 5, 2020 02:42 AM
Ceo4eva
Jan 28, 2019 02:09 PM
TheMarcAnderson
Southern California
Dec 2, 2013 02:02 PM
